Right Side Headlights stopped working
L_turn9
Location
Chester, Va
Chester
2006 Explorer 4.0 V6 4WD
Hi Gang,
I checked the bulb (replaced it) and checked the fuse. all seem to be working. My Explorer is a 2006 XLT and it's stock as far as I can tell. At least nothing externally appears to be modified except for a aftermarket radio.
What else can I check? I plan to check the plug with my test light to be sure it is getting 12v. But after that I'm not sure where to go next.
Ideas?
L_turn9
Location
Chester, Va
Chester
Hi Gang,
Ideas?
I just checked the plug that attaches to the back of the Bulb. Holding it with the connection down, the 1st connector at the left lights up with my test light when the low beams are turned on. The connector at the far right lit up when the high beams were turned on (the far left connector went off). I then tested the middle connector with my test light by attaching one end to the Pos. Battery Terminal and the other to the middle connector and it lit up meaning that middle plug was a ground (as I understand it).
So I tried 2 new bulbs (one was a LED) and neither lit up. I have no idea where to go next. Any suggestions?
TIA --
Explorer_PL
Rockland County, NY
06EB V8 & 07EB V6
LEDs are polarity sensitive so make sure it's plugged correctly. Can you test the bulbs directly with a battery ? Looks like you are getting 12v on both positives and ground is working. Fitment issue ?
J Loud ticking sound on right side when cold Stock 2006 -2010 Explorers 2
R Clunk at full right lock Stock 2006 -2010 Explorers 0
E Perfect storm right before the trip: P2105, P2107, P2004, P2005, P2008, P0301, P060A, ... long read. Stock 2006 -2010 Explorers 6
D The Explorer Feels Like Its Weaving / Weight Shifting Left and Right? Stock 2006 -2010 Explorers 3
J Installed 5r55s week later not shifting right 2008 4.0 2wd Explorer Stock 2006 -2010 Explorers 8
P Right rear brake light not working.... I'm stumped Stock 2006 -2010 Explorers 5
0 Maybe not the right place but... Stock 2006 -2010 Explorers 30
edwx Outside front right brake pad gone! Stock 2006 -2010 Explorers 8
D 2006 4.6L v8 right bank exhaust manifold gasket replacement Stock 2006 -2010 Explorers 5
E Part #'s for motor mounts: left & right, v8 Stock 2006 -2010 Explorers 2
T Brakes not working well right off the throttle Stock 2006 -2010 Explorers 4
C Something not right lights Stock 2006 -2010 Explorers 7
V car shaking when i turn right and left. more so turning right Stock 2006 -2010 Explorers 8
C Right front blinker problem Stock 2006 -2010 Explorers 3
F Do I have the right rearview mirror? Stock 2006 -2010 Explorers 10
T 07 Limited pulls right Stock 2006 -2010 Explorers 9
R found right reinforcement bracket broken Stock 2006 -2010 Explorers 2
M The A/C blowing cold from right but left is hot Stock 2006 -2010 Explorers 3
S Not running right. Need help Stock 2006 -2010 Explorers 4
edwx What's the deal with different spark plugs spec'd on the right and left sides? Stock 2006 -2010 Explorers 12
D interior noises and driver side wind Stock 2006 -2010 Explorers 5
N Passenger Side Moisture on Floorboard Stock 2006 -2010 Explorers 2
H Replacing driver side power seat switch Stock 2006 -2010 Explorers 0
M 2010 Explorer Drivers side window won't work Stock 2006 -2010 Explorers 0
A 2007 Ford Explorer Passenger Side CV axle Will Not Slide in Stock 2006 -2010 Explorers 31
H Front Driver side Axle binding Stock 2006 -2010 Explorers 0
A Roof Rack Side Rail Removal Stock 2006 -2010 Explorers 0
N Driver's Side Seat Motor Stock 2006 -2010 Explorers 3
B Rhythmic noise coming from rear driver side Stock 2006 -2010 Explorers 7
W Driver side CV-Joint Stock 2006 -2010 Explorers 13
M Excessive heat in center console and driver’s side floor Stock 2006 -2010 Explorers 3
D A/C issue, driver side hot, passenger cold, dont have dual AC Stock 2006 -2010 Explorers 0
E Replacing passenger side rear brake caliper - how do you bleed it ? Stock 2006 -2010 Explorers 8
Z 4L p0240 code, just need to verify side Stock 2006 -2010 Explorers 1
Mitchs07explorer Water in my passenger side floor pan Stock 2006 -2010 Explorers 2
J Front Differential Bearings - Where is passenger side? Stock 2006 -2010 Explorers 1
L Passenger driver side seat does not fold down Stock 2006 -2010 Explorers 0
F 2009 Driver Side Power Seat doesn't move forward Stock 2006 -2010 Explorers 2
C Driver's Side Passenger Power Window Lock Out Switch Question Stock 2006 -2010 Explorers 3
D Leaking Hose 2009 Explorer Driver Side Behind Rear Wheel Stock 2006 -2010 Explorers 4
E 2010 Explorer XLT - Issue with Dome 'Side' Lights Stock 2006 -2010 Explorers 7
A Pax side dash melting Stock 2006 -2010 Explorers 5
S 07 Mercury V8 no driver side heat.. Stock 2006 -2010 Explorers 2
C Passenger side a/c blows cold to warm back to cold Stock 2006 -2010 Explorers 0
B AC blows hot - compressor works - low pressure side VERY high Stock 2006 -2010 Explorers 3
H A/C Issue - Passenger Side Cold; Driver Side HOT Stock 2006 -2010 Explorers 3
P 2008 Ltd 4.6L needs muffler side flange from where Y pipe joins. Stock 2006 -2010 Explorers 4
S A/C coming warm from driver side vents Stock 2006 -2010 Explorers 3
08EddieCA New motor install - cross threaded driver side motor mount Stock 2006 -2010 Explorers 12
Similar threads
