Carl455
2005 Ford Explorer AWD V8
Hi all!
Ive done lots of research but this problem still has me stumped.
2005 Explorer
Symptoms:
-neither of the rear running lights work (the fronts do work)
-passenger side rear directional and brake light do not work. The front passenger side direction does.
-automatic headlights work, but the dash lights do not work when automatic lights are used. The dash lights do work when the headlights are turned on manually.
-the license plate lights do not work
-third brake light does work
-both the driver's side brake light and directional work
-reverse lights work
-at one point the driver's side directional and brake light were not working, for a day
What I've done:
-replaced the rear bulbs
-cleaned the connections of the rear bulbs and swapped the sockets
-cleaned and inspected the connection at the multifunction switch in the column, everything looked fine.
-cleaned and inspected the connection at the headlamp switch.
-inspected a bunch of fuses, I forget which ones.
This has got me stumped!
I suspected it may be a ground problem but Ive read the two lights share a common ground.
I have also read there may be a dirty connection at some trailer light junction. it looks like a b**** to get to.
Any Ideas?
07gtman
Chicago IL
2005 Mountaineer 4.6 AWD
did this happen all at the same time?
Carl455
Im not sure if this happened all at once or over a period. Right as I saw the right rear directional wasnt working I noticed all the other lighting symptoms. So probably all at once but there could have been malfunctions before too.
The only malfunction which I noticed existed before the right turn signal was the dash lights not comming on with the automatic lights. Thats been happening a while
07gtman
Chicago IL
i would start with the battery grounds, there should be one to the body of the car and one to the engine.if they are dirty or lose clean them..
G 03 explorer sport no hazards at all and no right turn signal when marker or headlights are on Stock 2002 - 2005 Explorers 7
E 2003 Explorer Sport-Right Brake light does not work and turn signal doenst blink Stock 2002 - 2005 Explorers 4
T Wire problem on Right Brake lamp/turn signal only Stock 2002 - 2005 Explorers 3
M 2005 Explorer 211xxx Miles. left and right low beams wont turn on. Stock 2002 - 2005 Explorers 4
shadowless127 Right turn signals stopped working, then came back, then stopped Stock 2002 - 2005 Explorers 0
C wierd problem when I stop and turn right only Stock 2002 - 2005 Explorers 4
J Right turn arrow on dashboard inop.. Stock 2002 - 2005 Explorers 1
R Right front end right turn noise... Stock 2002 - 2005 Explorers 2
J That's not suppossed to happen right? Radiator hose + sidewall of the radiator broken. Stock 2002 - 2005 Explorers 13
9 Crack on right side of radiator Stock 2002 - 2005 Explorers 8
S Front right wheel binding when turning? Stock 2002 - 2005 Explorers 10
F 2003 Explorer squeal with right turns only (sounds like brakes) Stock 2002 - 2005 Explorers 22
R Pulls left when accelerating & right on decel Stock 2002 - 2005 Explorers 3
H right valve cover on 4.6 real easy to break Stock 2002 - 2005 Explorers 0
9 Right rear wheel locked uo Stock 2002 - 2005 Explorers 1
9 Right rear front grinding squeaky noise Stock 2002 - 2005 Explorers 4
G 4.0 SOHC Right Side Cam Chain Head Scratcher Stock 2002 - 2005 Explorers 15
T Stuck? Right Rear Caliper Stock 2002 - 2005 Explorers 8
M What is that noise, when turning to the right? Stock 2002 - 2005 Explorers 4
K 2005 Ford Explorer advancetrac with V6 4.0 L sohc engine will start and cut right off broke TP sens Stock 2002 - 2005 Explorers 0
P right front window won't go down... Stock 2002 - 2005 Explorers 2
M Steering Wheel Crooked -- Pull to Right Stock 2002 - 2005 Explorers 4
K Right Rear Brake Light/Signal help Stock 2002 - 2005 Explorers 5
D Engine wont run right unless memory reset Stock 2002 - 2005 Explorers 3
M Documentation and Diagnosis. Learning to do it right. Stock 2002 - 2005 Explorers 2
S 4.6L V8 - Why are valves on right side brown but left side silver? Stock 2002 - 2005 Explorers 3
N Growling in the rear stops when steering wheel is jerked to the right Stock 2002 - 2005 Explorers 5
0 Stall right away when shift to gear - R or D Stock 2002 - 2005 Explorers 9
imp 2004 Starter Circuit: Sumpthin' Ain't Right! Stock 2002 - 2005 Explorers 5
B 2005 Explorer Limited Am I in the right place? Stock 2002 - 2005 Explorers 2
ProjectAviator 05 XLT V8 moaning when turning right Stock 2002 - 2005 Explorers 5
J 2005 mountaineer humming and slipping feeling with left and right pull Stock 2002 - 2005 Explorers 0
R hard to the right! Stock 2002 - 2005 Explorers 1
L Heat and AC not blowing right Stock 2002 - 2005 Explorers 6
G Right side valve cover Stock 2002 - 2005 Explorers 3
J Are rear Left & Right axle shafts different lengths? Stock 2002 - 2005 Explorers 2
C Right rear window goes up when pushing down button Stock 2002 - 2005 Explorers 4
N AC dripping on right, wet passenger carpet Stock 2002 - 2005 Explorers 3
T Need help finding a part. I'm obviously not using the right terms. Stock 2002 - 2005 Explorers 6
S Clank while in reverse and brakes applied. Right front caliper "play" Stock 2002 - 2005 Explorers 3
F 2005 Ford Explorer steering and Abs problems in right turns? Stock 2002 - 2005 Explorers 3
H Humming while turning right. Stock 2002 - 2005 Explorers 2
F Grinding noise when turning ONLY right, Stock 2002 - 2005 Explorers 5
M O2 explorer not running right help!! Stock 2002 - 2005 Explorers 0
N stalling when turning right Stock 2002 - 2005 Explorers 5
F Looking to identify my transmission to get right torque converter Stock 2002 - 2005 Explorers 1
M Poor fuel mileage, exhaust stinks, my converter(s) are probably toast, right? Stock 2002 - 2005 Explorers 5
E All 02-05 Mountys have 3rd row & leather, right? Stock 2002 - 2005 Explorers 9
2 Rear right side caliper stuck? please help Stock 2002 - 2005 Explorers 3
P Vacuum leak testing the RIGHT way! Stock 2002 - 2005 Explorers 9
Similar threads
