sheltonfilms
- June 9, 2010
- Hoover, AL
- 2013 Limited 3.5L
It's possible you have a spread terminal at the connector on the BCM that leads to the RR light. You are looking at the brown/white wire on connector 2280C?
Do a wiggle test. Put the connector back on, keep turn signal turned on, and try wiggling the terminal in and out, side to side. If it all of sudden works your terminal is probably spread.
As far as the two wire connector are the wires White/Violet and Black?
