Ring and Pinion brand advice needed
Polo Suafilo
Location
Lehi UT
Lehi, UT
94, Explorer Sport
I have been collecting parts for a SAS the last year. My original plan was to SAS my EX this spring and wheel all summer but with some family stuff prior to COVID-19 my wife and I decided to hold off until we can purchase another vehicle, hopefully soon. But in the mean time I want to get started on regearing my axles. this is my first time and I am wanting to try myself for the learning experience, so forgive my ignorance.
I have a HP 44 and 9in combo from a 79 F150 and have been looking a various R&P brand options. I have a line up on some Yukon gears for a decent price, but was just looking at Rock Auto and they have Ring and Pinion options for around $100 less. Should I skip on the Yukon set and go for the Richmond Excel or another brand from Rock Auto? Is Yukon as good as they are marketed?
The distributor I was going to purchase from also quoted me a minimal kit for the swap but I was hoping to do a more in-depth rebuild, just so I can have some peace of mind. Rock Auto has diff rebuild kits that are fairly priced from US Standard gear. Will these diff rebuild kits be compatible with the Yukon R&P?
Any advice would help.
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
Sorry for the delay, but yes you can use any rebuild kit with any gear set. Both Richmond and Yukon make good gears.
M 92 mazda navajo ring and pinion gear help Modified 1991-1994 Explorers 4
T front ring and pinion. Can't find 'em Modified 1991-1994 Explorers 11
B Ring & Pinion swap Modified 1991-1994 Explorers 7
B ring&pinion Modified 1991-1994 Explorers 3
K How Tough are Ring and Pinion to change out ? Modified 1991-1994 Explorers 6
R Ring & Pinion Modified 1991-1994 Explorers 1
T Ring and pinion? Modified 1991-1994 Explorers 5
fordpickupman Re-geared 8.8, do I need the tone ring Modified 1991-1994 Explorers 9
C Full circle snap ring question Modified 1991-1994 Explorers 6
T What's the part # or size of U joint snap ring? Modified 1991-1994 Explorers 6
F 5-760X Full-Circle Retaining Ring / Clip Part Number Modified 1991-1994 Explorers 4
9 twisting center diff on fron sas dana 30 to make pinion higher? Modified 1991-1994 Explorers 3
I Rack and pinion Steering on 1st gen X?? Modified 1991-1994 Explorers 7
davy crockett Correct rear pinion angle w/lift? Modified 1991-1994 Explorers 0
rngmStr PERCH/pinion angle SOA - SBL Modified 1991-1994 Explorers 6
Dre Pinion shaft Modified 1991-1994 Explorers 6
WickedWindsor Pinion yoke from Jeep work on TTB D35? Modified 1991-1994 Explorers 2
M Does anyone know the brand of hood Spotlight for a Jurassic Park Explorer? Modified 1991-1994 Explorers 0
E what brand lift Modified 1991-1994 Explorers 3
