RobertFord
- November 14, 2011
- Amsterdam, Netherlands
- 1991 Ford Explorer XLT
All,
I'll be replacing my rocker arms and pushrods tomorrow in an effort to get rid of the nasty rattle my X has developed in its 4.0 OHV. Now, I know the lifters might be the actual cause of the rattle, but as those parts are already expensive in the US and even more so in the Netherlands, I'd rather have a look and see if and what lifters might need replacement before splurging on that.
Now, I have bought the following parts:
- FelPro permadry gaskets for the valve cover and upper intake manifold
- 12x rocker arm
- 12x push rod (standard size)
I intend on going by the following procedure:
Before: put new rocker arms and pushrods in ATF for the night
1. Disconnect any lines, marking them where they got from (A/C is already removed so no need to worry about that)
2. Drain radiator a bit
3. Remove upper intake manifold and then valve covers, inspect current state of rocker arms
4. Remove rocker arm assembly and push rods from side #1
5a. Strip rocker arm assembly of old parts
5b. Clean all pars that will be reused with brake cleaner/bit of sanding paper/cloths
5c. Reassemble rocker arm assembly
6. Remove old gasket materials, clean up anything that can be cleaned up
7. reinstall rocker arm assembly, make sure everything seems right when compared to other side.
8. Repeat for other side
9. Tighten lower intake manifold bolts
10. Install new valve cover gaskets (applying some RTV here and there, I believe there's an instruction coming with the gaskets)
11. Install valve covers
12. Install upper intake manifold
13. Reconnect all the lines
14. Pray it works
Did I miss anything here? Any other tips / tricks that might help reduce the chance of failure?
- 12x rocker arm
14. Pray it works
