Raceit
- August 28, 2000
- Overland Park, KS
- '91 Explorer 2DR 4WD XL
Very soon I will be tearing into my engine to fix my valve clatter probelm.
I got some really good prices from http://www.stevensparts.com for the rocker arm assembly and the roller lifters. The cool part is that the rocker arm assemby comes with the pushrods and its the complete set. Not just for one side. So that will get me the rocker arm assembly, the push rods, and the roller lifters.
Can I replace all these things without taking off the heads or the intake manifold? From what I understand you might have to take the intake manifold off. I really don't see that as a big deal since you're in the engine that far anyway. But are you able to get the lifters out and put new ones in without taking off the heads?
Plus any insight into this process would be great.
And I have the roller lifters and not the hydrolic lifters on my 4.0L OHV right?
Incase anybody is wondering. The prices from stevensparts.com are $120 for the rocker arm assembly. That includes both sides and pushrods. Then $130 for the roller lifters. These are "take-off" parts and I'm fine with that.
Also as a side note... I have tried everything to try to fix the valve clatter. It's at such an extreme point in the problem that nothing else will fix it. It sounds like parts will start to come though the valve cover. It's pretty bad. But the engine doesn't burn oil and it even still has good power. So this is a cheap solution to an engine that has over 190K on the meter and I don't plan to hot-rod it any time soon.
Thanks for the help.
