rocker arms not lining up with valves (4.0 ohv)
red.EDDIE.4x4
Tulsa, Oklahoma
'93 Eddie Bauer 4x4
i have done some searching and found nothing. hopefully somebody has some input here. this is my problem. the rocker arms are not lining up with my valves. they are sealed power rocker arms. the guides/springs and junk are all factory.
one solution i had was maybe machining out some of the material on the side of the rocker arm or on the side of the aluminum things that the guide rod slides thru. maybe? any ideas? thanks!
Dono
347 V8 Limited turbo
Winnipeg, Manitoba
00 Limited V8
Thats normal. Mine are the same way. Not the answer you wanted, I know.
Maniak
Moderator-Stock 91-94
Staff member
Moderator
Vail, Arizona
1992 XLT 4x4
side subject. Assuming that paint on the springs. The oil will eat it up and that paint will flow in the oil. You don't have "much" but I've seen paint plug an oil pickup screen before (they painted the entire valley on the block).
As for the orig question. My rockers didn't quite line up either but I don't remember them being that far off. Machining is the only thing I can think of, but the way the rockers are held onto shaft, I don't know if that will work. (pins/springs)
~Mark
red.EDDIE.4x4
Tulsa, Oklahoma
'93 Eddie Bauer 4x4
@Dono- glad to know somebody else has the same type of issue.
@Maniak- yes thats paint on the springs and i was planning to get it off. eventually...but i will now that i know its got the chance to mess with the motor.
i may try to machine one or two first to see if its possible. ill just wait for a few more opinions and see what becomes of it.
Dazzlin' Dave
94 Ranger Splash
Is there a chance that 1/2 the rockers are different and some are in the wrong locations? Weird...
I'm looking into some ratio rockers...
http://www.summitracing.com/search/.../engine-family/ford-v6?keyword=roller rockers
It says Pedestal mount and a 4.0 has a rail system... WTH? How is that gonna work?
As for paint inside the motor, I read an article in either Hot Rod or Car Craft (decades ago) that you can paint your valley with Glyptal ($40+/pint) and the oil won't sit in the valley, Seals up the porosity of the cast iron and gives it a smooth surface for the oil to run off so it sits in your oil pan and not on top of the block/heads. I used to use a lot of it sealing substation transformer gaskets and it is highly oil resistant. The mineral oil in a transformer is somewhere between baby oil and diesel fuel... nasty stuff! One day I had to go spelunking in a x-frmer chest deep in the oil! Talk about a bad day!
Dazzlin' Dave
94 Ranger Splash
Looking again, the rocker misalignment can't be normal!! There is DEFINITELY something wrong there!! I wouldn't run it like that if it was mine! Do some more investigation, contact Sealed Power, send a pic and ask them WTF?
Another point on ratio roller rockers is spring bind! I didn't know if I was gonna go with 1.73:1 or 1.8:1, leaning toward the smaller just in case of valve clearance, but I didn't think about spring bind!
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
It almost looks like the intake and exhaust rockers are reversed from where they should be on every cylinder. Looking closely you can see they are different.
vq5speed
1991 XLT Manual Locks
Stockton,Ca
Its just an illusion. The rockers are all identical. When I replaced my rocker arms I notice when re-assembly those pillars that the bolt goes through that holds the shaft assembly onto the head. The hole that the bolt goes through in the pillar is bigger in diameter then the bolt quite a bit. So the pillar can be shifted on the shaft more left or right centering the rockers more even. I think this person or someone who had the assembly apart assembled the pillars to far to one side slightly.
J 98 Explorer 5.0L Valve springs and rocker arms? Under the Hood 0
K Rocker arms vs Cam Under the Hood 14
3 How to remove rocker arms????? Under the Hood 1
Mtn8er How To: Install Full Roller Rocker Arms Under the Hood 12
C New Rocker Arms - Noticeable power gain Under the Hood 2
section525 How To: Install Camshaft & Rocker Arms Under the Hood 34
L Problem after replacing rocker arms Under the Hood 2
S Roller rocker arms-Will they fit OE valve covers? Under the Hood 4
S Better Rocker Arms For 91 Sport? Under the Hood 12
R rocker arms, lifters, and pushrods ? Under the Hood 8
M 95 explorer rocker arm bolts Under the Hood 6
G Rocker Arm keeps coming off Under the Hood 18
M 4.0 Rocker arm spacers Under the Hood 1
P Timing chaine question and rocker problem Under the Hood 1
L push rod rocker roller? Under the Hood 0
N GT40P rocker torque??? Under the Hood 1
M Rocker arm tick - Experiences? Under the Hood 1
E Rocker arm assemblies Under the Hood 2
C E303 Cam and 1.7 Rocker rollers Under the Hood 67
H Rocker Spacers? Under the Hood 1
P lifter/rocker ticking at cold start up Under the Hood 2
section525 Roller Rocker Noise after install - Drivers Side Only Under the Hood 2
T 5.0 cam swap roller rocker questions Under the Hood 4
R 1.7 Rocker questions Under the Hood 6
M Potential Rocker Panel fix Under the Hood 12
Fredness Rocker arm ratio for a 3.0 V-6?? Under the Hood 3
H radius arms are also called sway bars right???? Under the Hood 11
