RockRangerII the build up. | Page 28 | Ford Explorer - Ford Ranger Forums - Serious Explorations
After loosing my last ranger a bit over a year ago I finally got onther one to replace it. The truck I am starting with is a 1993 ranger 4X4 xl standard cab short bed. It is pretty much a bare bones truck. No AC no cruise and a manualt t case. It also has a 4.0 and a 5 speed with 3.73 and an open rear diff. When I purchased the truck it came with a 2.5" rancho lift 31" bfg AT tires on aluminum rims.
I have had the truck around 3 months now and have put about 3000 miles on it sofar. Over that time I have noticed a few things about it. When they installed the lift instead of installing longer brake lines they installed limit straps that limit down travel to about 1" from ride height and also removed the sway bar. They also didnt lift the rear at all and it has a serous case of butt dragging.
RockRanger
Elite Ranger
Fresno CA
86 ranger no more
Callsign
KK6TDL
After I got the doubler stuff done I started working on the front winch bumper. Didnt get to far today. I'm still trying to figure out how to make it. Didnt get to far on it today. Hopefully I can get more of it figured out tommorow.
RockRanger
Elite Ranger
Fresno CA
86 ranger no more
Callsign
KK6TDL
I had to stop early cause I had to go pick up something I bought yesterday :D
DB_1
Elite Ranger
La Quinta, Ca.
97 SC Ranger xlt
Cool :thumbsup: I feel better now that you have a trailer to tow my rig home if something breaks :p
RockRanger
Elite Ranger
Fresno CA
86 ranger no more
Callsign
KK6TDL
Actually it isnt really mine. It is Tracys anniversary present. We have been dating a bit over 4 years now.
DB_1
Elite Ranger
La Quinta, Ca.
97 SC Ranger xlt
Congrats...but I think a ring is in order mr. :D
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
I love women who can deal with a gift like that :D
tdavis
Linux Guru, Jack of All Trades
Staff member
Admin
Pinole, CA
2001 F250/XLT Superduty
Callsign
KG6MAX
As for the speedo cable - hit the yellowpages, look for a speedometer shop. Take the whole cable, they will re-use the ends and can make you a longer one.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Ditto. :D
Matt, why not just get a supercab speedo cable at the junkyard?
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
I had one remade a long time ago at a local speedo shop and it was super cheap.
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
I went to Autozone and bought a speedo cable, it was about 18" longer then my factory one in stock and cheap.
Something to consider.
Any pool table in town is a great palce for a cheapo shifter knob
kidding! Nice trailer, talk about a boost to your hobby!
Now will a Jeep and a Ranger fit on that sucker? hahahaThe work yuo have done on this ranger is awesome Matt, its going to be a monster!
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Ditto! :p
Why do you need a speedo cable on a trail rig?
If you cut out that sheet metal in front of the radiator above where you have the winch mocked up, you can raise the winch height up quite a bit, so it won't hang down so much.
RockRanger
Elite Ranger
Fresno CA
86 ranger no more
Callsign
KK6TDL
Cool I will check out autozone and see what they have.
The trailer is a 16' deck. Just big enough for 1 vechicle. I dont think my 1/2 ton chevy would like pulling a 30' trailer with two vechicles. Need to upgrade tow rigs before I get that trailer.
RockRanger
Elite Ranger
Fresno CA
86 ranger no more
Callsign
KK6TDL
BKennedy said:
Ditto! :p
I need the speedo mostly for the odomiter cause the gas guage doesnt work :rolleyes: As far as the winch that was as high as the jack would take it. I need to cut the area behind the grill to get the winch in higher and farther back. Still working on getting the perfect spot.
I took it for a spin yesterday and played with 4 lo lo in the street out front. Sure is nice driving over curbs with out having to give it gas.
I also ordered some new diff covers this morning to replace the leaking rear diff cover. They should be here next week and then after that I can install my rear locker at the same time :D
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
why not fix the gas guage?
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
Yes but anything is possible, making the old sender talk to the newer gage, or using and older gage behind the dash, or an aftermarket gage, or using resistors to get the right signal, etc
RockRanger
Elite Ranger
Fresno CA
86 ranger no more
Callsign
KK6TDL
Gas guage doesnt work because the float is broken so it sinks to the bottom. Only reason why it doesnt work. Need to get a new float.
