  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
Rolling very slowly in park on hills
reklis
Las Vegas
2000 ford ranger 5.0
When I'm in park on any bit of a hill my truck is rolling very slowly, whether I'm facing up or downhill does not matter. It is an 01 explorer 5.0---I currently have the front driveline out but I don't see why that would change anything. it is not clicking or making any noise, not jerking or anything---just very slowly rolling......can anyone tell me what's happening? I would appreciate any help--thank you in advance
alohamonte
Glendale, AZ
1998 Explorer 4.0 4x4
I believe it's called the parking pawl and it's located in the transmission. By locking the transmission the vehicle won't roll. Sounds like it snapped or unhinged.
SoNic67
Newport News, VA
2001 V8 (Eddie Bauer) AWD
It changes everything because you have an AWD system.
Right now you are on the path of damaging the Center Differential (or Transfer Case how some call it colloquially) because you drive without that axle.
koda2000
x
This. Research "creeping in PARK with front driveshaft removed".
1997XLTRollover
1996 AWD 5.0
I found this out the fun way too OP. As others have said, it's because you don't have the AWD hooked up. The AWD transfer case cannot fully lock, so will slip when in park. If the front tires are not hooked up to hold it from slipping, the front drive connection on the transfer case slowly turns and your truck rolls.
SoNic67
Newport News, VA
Well, the Owner Manual tells us to always use the parking brake...
It is a good practice for any car with automatic transmission - to save the parking pawl inside transmission in case that somebody hits slightly your bumper while you are parked.
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
^ You nailed it. The reason it's called a PARKING brake, not emergency or e-brake.
And we all know how much fun seized parking brakes are to work on from non use.
reklis
Las Vegas
thank you guys all for the response! I learned a lot about my t-case! I think I'm going to put a 4406 in. the reason my driveline is out is because it needs rebuilt and the truck is my DD. but now I think if I need to re built my driveline I might as well build it to match that t case---I've been reading and it looks like an easy swap
1997XLTRollover
1996 AWD 5.0
True parking brake should be used, but not everyone has a working parking brake and a lot of people won't pay to fix it with an automatic vehicle. Yes I know it should be fixed, not trying to start an argument haha.
SoNic67
Newport News, VA
In VA you can't pass the yearly inspection without it. And yes, it's a pain to fix a rusted one.
koda2000
x
Well, if you remove the front drive shaft on an AWD and your parking brake doesn't work, don't park on any hills, or carry wheel chocks around with you I guess. :D
1997XLTRollover
1996 AWD 5.0
I used to just always park on hills and let the truck sit back on the curb or parking stone until I got it fixed. But yes. Bad news if you have to park somewhere and your parking brake does not work lol.
F Rough/Rolling/Stuttering Idle, 00 SOHC Stock 1995 - 2001 Explorers 7
P Squeaking When Rolling, Goes Away When Pressing Brake Stock 1995 - 2001 Explorers 4
D Rolling back on hill. Stock 1995 - 2001 Explorers 10
J Drivers Window Rolling Half Down Stock 1995 - 2001 Explorers 3
D Rolling idle & periodic overheating Stock 1995 - 2001 Explorers 8
T truck seems as if its dragging...not rolling along without friction Stock 1995 - 2001 Explorers 1
S Windows "catching" when rolling down? Stock 1995 - 2001 Explorers 4
W Rolling w/o Firestone Stock 1995 - 2001 Explorers 1
T Rolling Door Locks Stock 1995 - 2001 Explorers 3
D Squeak when rolling 99 Sport Stock 1995 - 2001 Explorers 5
C Rolling Backwords Stock 1995 - 2001 Explorers 4
M 99 Mountaineer 5.0 running very hot (not overheating) Stock 1995 - 2001 Explorers 22
J Input needed on a very important Explorer related decision. Stock 1995 - 2001 Explorers 14
Craigerz Vents not blowing very hard Stock 1995 - 2001 Explorers 1
V No Air Flow (Very Little) From Any Duct Stock 1995 - 2001 Explorers 4
S Exhaust Smoking Very Concerning Stock 1995 - 2001 Explorers 7
A Brake pad issue...very odd, here's the evidence Stock 1995 - 2001 Explorers 11
C Rear wheels VERY hard to turn, driveshaft won't turn by hand. Stock 1995 - 2001 Explorers 30
K engine died, very odd electrical issues and no start Stock 1995 - 2001 Explorers 9
D Broken EGR line. VERY rough idol Stock 1995 - 2001 Explorers 2
W Very Random Stumble/ Stalling Stock 1995 - 2001 Explorers 3
G 98 5.0 Explorer AWD – very hot front differential Stock 1995 - 2001 Explorers 9
T Solved 98 mountaineer 5.0 running very bad HELP! Stock 1995 - 2001 Explorers 16
C Help!- 96 Explorer Very Bad Idle Stock 1995 - 2001 Explorers 13
O 97 X Vin VERY bad fuel leak under hood Stock 1995 - 2001 Explorers 1
T Very audible clicking/clunking sound when key is turned on. Stock 1995 - 2001 Explorers 6
S Very loud Stock 1995 - 2001 Explorers 3
M Very Loud ticks on hot 4.0L SOHC Stock 1995 - 2001 Explorers 5
F Very strange AC problem Stock 1995 - 2001 Explorers 8
S Very Low and Rough Idle, Went Through Large Puddle, Difficulty Starting Stock 1995 - 2001 Explorers 4
D very little air from rear AC vents Stock 1995 - 2001 Explorers 2
J This is very weird Stock 1995 - 2001 Explorers 2
T Not very "computer savvy" as it were Stock 1995 - 2001 Explorers 3
A Very poor ride quality (01 EXP 5.0L AWD) Stock 1995 - 2001 Explorers 14
K Very strange door lock problem Stock 1995 - 2001 Explorers 2
M Very faint grinding noise from 0-5mph Stock 1995 - 2001 Explorers 4
B Stalling during idle and very low speeds. Stock 1995 - 2001 Explorers 7
M Very low airflow Stock 1995 - 2001 Explorers 6
J Very odd, beats me, but may be easy to you, take a look! Stock 1995 - 2001 Explorers 34
B very strange engine noise Stock 1995 - 2001 Explorers 0
I Very expensive balancer bolt Stock 1995 - 2001 Explorers 8
Gabe96Explorer VERY SLOW SHIFTING when cold Stock 1995 - 2001 Explorers 5
pj8847 Very strange Cooling/overheat issue... Stock 1995 - 2001 Explorers 15
tgreene92 very high idle in park Stock 1995 - 2001 Explorers 2
B Very Rough Idle/Misfire Stock 1995 - 2001 Explorers 7
J I replaced my heater core, but it isn't getting very hot! Stock 1995 - 2001 Explorers 16
2 Very hard to turn Steering Wheel (Power Steering?) Stock 1995 - 2001 Explorers 12
R 99 4.0 ohv very slight jerking at idle Stock 1995 - 2001 Explorers 0
J ranger very hesitant at high speeds Stock 1995 - 2001 Explorers 5
S Got a few codes, very rough idle stalling HELP! Stock 1995 - 2001 Explorers 17
Similar threads
