dj747
- April 2, 2008
- 2001 sport trac
I have a 2001 sport track 4.0 SOHC with a DTC ( check engine light ) that likes to idle very rough when cold, almost to a stall. I pulled obd II codes and came up with p0171,p0174 bank 1 + 2 too lean the first time. I checked for vacuum leaks a didn't find any. I cleared the codes and DTC poped up again with same codes but this time included a p0300 multiple cylinder missfiring and p1506 low signal on iac. Is it possible that a bad idle air control valve can cause missfiring and the fuel system to be too lean??? I have checked the valve resistance and voltage and it reads fine, and all the other sensors related to the system are reading fine too. After the engine warms up it runs and idle very smoothly even though the check engine light remains on. what might be the problem? PLS HELP...
THANKYOU.
THANKYOU.
