Rough Country lift | Ford Explorer Forums - Serious Explorations
Rough Country lift
92 Explorer
Pa
96 XLT
Hello guys i just wanted to post real quick and get some input. I am thinking of a 4" lift from Rough Country. I was wondering if any one did that set up and had pictures and also do you know if i would need extened brake lines with that. Thanks alot for any information
I used to run the 4" Rough Country with 33x12.50s. I had extended brake lines up front.
I'm running the 4" Rough Country and a 3" body and yes you will need extended brake lines. If you have RABS you can use the front lines from a F250 which are 4" longer and the good thing about those is that you local autoparts store may have them in stock so you dont have to wait for them to be ordered and they are usually cheaper.
91exploreron37 gave me some parts numbers in another thread... here they are:
(NAPA part numbers!)
Left Front -381186
Right Front-381184
