Rough engine idle and miss | Ford Explorer - Ford Ranger Forums - Serious Explorations
Oxthe3rd
Hamburg NY
1992 Ford Explorer XLT
I was driving when my 1992 developed a miss randomly buy very noticeable. I got home ran a koeo and koer test and got 157 and 158 on koeo and 159 on koer. I believe that's for maf sensor. When running I unplugged the sensor with no change to the rough idle.
Any ideas before I get a new maf?
natenkiki2004
Blue Bomb!
Location
North Idaho
1991 & 1994 Explorers
Grab some cleaner and clean the hot wires off. People say you must only use MAF cleaner but that stuff is expensive. I've used Brake Parts cleaner without issue. Vinegar as well but you need to let it soak. Whatever you do, don't touch the wires or brush them. Liquid only, no compressed air.
malohnes
SE Alaska
'91 xl m5 4x4
Electrical contact cleaner works better than brake cleaner for the MAS sensor. Definitely clean it first before buying a new one. Reset the engine computer too.
FixingDaily
Boise, Idaho
94 Explorer XLT
I would add that you should use the "No Residue" type electrical contact cleaner. There is also the type of cleaner with a lubricant added that may mess things up.
Oxthe3rd
Hamburg NY
Alright so I cleaned the sensor with contact cleaner and letting it dry over night. I think i found what caused it. I have a decent amount of oil coming in from the oil fill tube into the intake that sprayed all over.
Oxthe3rd
Hamburg NY
Cleaned MAF sensor solved most of the misfire but i still have a miss at steady throttle around 2000 rpm. It doesn't happen constantly but does set off the check engine light. check engine shuts off almost immediately after.
Im going to try to pull any codes i can and will update. I think im going to change the fuel filter and check my plugs although the plugs were changed recently.
Oxthe3rd
Hamburg NY
Finally replaced the mass airflow sensor and its all fixed
pkn
Houston, TX
'92 '05 '10 2WDstockXLTs
Thanks for posting back. It is important to know -- what worked... and what didn't.
