rs2k
- December 29, 2012
- Wichita, KS
- 2014 Ram 1500 Laramie
I'm trying to track down the cause of an occasional rough idle and once in a while slight stumble upon acceleration from a dead stop.
The idle seems it's best after the idle RPM comes down from a cold start. It seems its worst after a hot start. I've also noticed the engine takes a little longer to turn over during a hot start than a cold start.
I have a rock solid 17 inHg of vacuum at idle.
I've cleaned the MAF a few times with MAF cleaner.
I have new O2 sensors.
I have new plugs, (recommended ones), new wires (recommended ones) and a new Camshaft Position sensor installed correctly. Cylinder one at TDC with the proper alignment tool used.
Engine has 130K miles and seems ot make good power. I have no problem towing a 4500 lb boat.
Any ideas on what I should do? Maybe my MAF is going bad? Maybe 17 inHG is too low and I have a vacuum leak somewhere? I suspect I might have a small leak somewhere because my fuel trim is about 20% extra rich at idle according to my OBDII scanner.
Thanks for any help!
