Rough idle and running horrible! | Ford Explorer Forums - Serious Explorations
TXXLT
The Woodlands, TX
1999 Explorer XLT
So here is my situation:
A coolant hose breaks and spews coolant in the motor, (mostly on passenger side). I take it in to the dealership since I still have Ford ESP extended warranty. Of course the dealer doesnt cover the hose and I end up paying for it. The problem is that when the coolant hose broke, the engine immediately started to idle very poorly and run as if it were on 4 cylinders ( I have a 99 2wd with the 5.0 V8). The dealer suggested that I needed a tune up badly and that some of the electrical may have been affected. Subsequently, I changed the plugs (which looked horrible) and wires. Reset PCM via removing negative battery cable. After the plug/wire install, the Explorer runs great and I was satisfied. Not for long! About 5 minutes in to the drive, it begins to start surging and idling horribly. Now it is running worse than before. CEL flashes then goes off. So now I'm :frustrate and :mad: I looked back at the paperwork from the dealership and see a diagnostic and code P0304. So is it possible that I may have a bad Crankshaft position sensor that would cause this? Or could it be coil packs? Anyone have any ideas? Thanks in advance!
Fixed!
How? Would be nice to know in case someone else has similar problem.....
