pteepee69
- February 7, 2010
- Lawrenceburg,Ky.
- '94 Explorer XLT
I have posted in several threads trying to get answers. Still not getting help. I will try once again. Have a '94 Explorer. Idles rough. So far I have replaced lower intake gasket, upper intake gasket, fuel injector o-rings, thermostat, radiator cap, battery cables, replaced 2 vac lines going to EGR that had holes in them, cleaned the MAF and Maf housing twice, cleaned the throttle body, ran Seafoam through the PCV line, put Seafoam in the gas tank, performed a pressure test(engine cold and engine hot) held pressure for 10 minutes until I released it. Ran codes and I am getting KOEO 114: CM 157, 189, 192: KOER 116.
Forgot to mention I also found 2 holes in my breather tube that I have patched temporarily until getting my idle issues solved. Had my coil tested and it checked OK.
I have been trying to get help, but I thought maybe I have been posting in the wrong place so I am trying again. Any help would be appreciated.
