Vr1967
- May 25, 2023
- Liberty MS
- 2007 Explorer Eddie Bauer
Have a 2007 Explorer EB 4.0 V6
Did a search, but didnt turn up anything similar
Recently it has gotten where when it get to 165-170 degrees (per a Scan Gauge 2) it starts running very rough, then dies.
Before, wife said it would occasionally have a “dead pedal” so the throttle body and pedal were replaced. She ran it a while and now this.
Today was the first day I have had time to mess with it, due to work, (and having a 3rd vehicle)
Vehicle has had plugs, wires, tb, pedal, coolant temp, crank position, and fuel rail pressure sensors (at which time upper intake and valve cover gaskets were replaced) in last 10k miles
Only codes it is showing at moment are P2195 & 2197
MAP sensor was reading steady 4.4 until it warmed up then it went erratic with the idle.
Runs perfect until it gets up to operating temp.
At what temp does egr start to open? What else is temp controlled that I need to check?
Been wrenching on my own stuff for 40 plus years, but the newer electronic stuff stumps me now.
Thank you for any input
