viking74
- September 24, 2008
- Wake Forest, NC
- '98 XLT
Hello, I have a '98 Explorer XLT with 4.0 SOHC. I am having an issue with a rough/maybe even low idle when warm. Usually occurs when sitting at traffic light. Just a rough idle for a couple of months now. Tach reads around 600 at warm idle. Engine performance is great/smooth above 1k rpm. Also, no check engine light or DTCs for months now. I have replaced several items since this problem with no solution yet. Here's what has been replaced: Crank & cam sensors, IAT sensor, cleaned MAF, new fuel injectors, new fuel pump and filter, new PCV valve and replaced degraded PCV hoses, new intake gaskets, cleaned IAC, new coil, wires and plugs. No smell of gas when idling, no black smoke from exhaust. New air filter. Plugs looked decent when recently pulled...not to full of carbon and gap was in spec. Tested fuel pressure...is at 30psi at idle. Pulled EGR valve and verified no leakage when valve closed. I'm out of ideas! Help me out guys!
I also tried driving car with MAF disconnected for testing purposes. The car still had idle issue. When MAF was disconnected, trans shifted erratic and lots of hesitation when starting from a standstill. Also, noticed that the CEL did not come on after disconnecting MAF and driving for approx 10 miles. CEL does come on when key on engine off. So, CEL bulb works. So, I just connected MAF back again and runs fine with the exception of this idle issue.
Also, I have the obd2.com scanning software I've used for years. I noticed that this Explorer shows long and short fuel trims constant at -100% all the time, both banks. Seems strange to me. Here's some other sensor info at idle:
Running in closed loop, Load: 29.8%, ECT 187, all fuel trims -100%, rpm 645, sparkadv 18.5,iat 86,maf 0.57 #/min,TP 18.8%, misfire all cylinders at 0%.
