97ExplorerAWD
- March 2, 2008
- New Jersey
- 97 Explorer 5.0 AWD
ok here I go I just got a 97 Explorer Limited AWD had it for a few days everything was good. one day I'm driving and it throws a check engine light I didn't really pay to much attention to it few days later I go to start it and it starts then stalls so I start it again it starts but runs a really rough idle sometimes feeling like it's going to stall so I talked to a few people and they told me it might be the MAF sensor so I unplug the MAF and it starts up fine no rough idle it just idles at a higher RPM dumping more fuel so I plug back in the MAF runs bad again I wanted to make sure it was the MAF so I went out and bought an OBDII Reader but when I scan the codes nothing about the MAF sensor comes up here are the codes I got (Generic Code) P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control (Ford Code) P1137 Lack of Heated Oxygen Sensor Switch - Sensor Indicates Lean (Ford Code) P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean Bank 2 but here's the weird part I cleared the codes unpluged the MAF sensor and did alot of driving the check engine light came back on so I scanned it again but the only code that came up was (Generic Code) P0102 Mass or Volume Air Flow Circuit Low Input so why is it when I unplug the MAF it runs fine and the only code that comes up is for the MAF but when I leave it pluged in those other codes come up and it runs like crap but nothing about the MAF comes up???
