davem
- February 3, 2004
- Rochester, MN
- '01 XLT
I've been battling a 'rough idle on cold start' for quite awhile (couple years) ... I lived with it long enough and am trying again to resolve it. Typically, its running good after a few miles down the road once warmed up. I dont recall the exact engine codes, but I know it included lean conditions and misfires.
I have a 2001 XLT V-6 with 147,000 miles.
2-3 years ago, I replaced plugs and wires.
A week ago, I had upper and lower intake gaskets replaced. The codes have been reset and the CEL is not lit up. Its running better, but will still die if I dont work to feather the gas pedal on a cold start.
I've read many posts to get an idea of what to try next. Do I need to wait for the CEL to come on ? I assume its just a matter of time until it comes on, but I gotta ask: How can I have this bad start-up idle and NOT get the CEL to light up ? Does that alone help pinpoint the cause ?
With my current condition, of bad idle at cold start, and no CEL, which of the following (which I've ran across in my forum searching), if any, make sense to pursue:
IACV
IAT sensor
MAF
Engine Coolant Temp sensor (this is a new one for me, but very intriguing)
PCV elbow
Cannister Purge Valve
ignition coil
fuel pressure
O2 sensors (could they be bad, but not throw a code ?)
other ?
Am I being unrealistic about achieving a good cold start idle ? I get that its 12 years old and all, but a buddy of mine drives a 18 year old rig that idles just fine.
I dont want to spend a ton of money obviously, but hope I can make some improvement from what I have.
Thanks.
IACV
IAT sensor
MAF
PCV elbow
ignition coil
fuel pressure
other ?
Thanks.
