Superman1974
- December 19, 2017
- Pensacola,Fl
- 2008 Ford explorer xlt
Does anyone have any suggestions how to raise the idle higher than the factory setting on a 2008 Ford Explorer XLT 4.0 single overhead cam I've already replaced the throttle body the throttle position sensor all the spark plugs plug wires crank sensor harmonic balancer fuel pump and all the injectors still has rough idle when you put in gear when you raise the idle the gas pedal around 150 RPM it clears up any suggestions anything will be helpful thank you
