My 03 XLT Expoder is trash
Rough idle? Falter at shift point? Let me explain what I have found.....
Ford has an issue with the transmission called the OD servo bore. The way the transmission operates, it uses the OD servo to engage 2nd gear... since it really does not have one, it has 1, OD,3, 4 (3rd and 4th being the intermediate band) and then 5th(OD) again. The OD servo bore is used for both 2nd and 5th. If you are getting shudder or stumble or DELAYED SHIFT POINT on shifting between 1&2 or 4th and 5th, it is the tranny with a worn servo bore (PLEASE READ AS: TRANSMISSION IS TRASHED BEYOND REPAIR AND MUST BE RE&RE AND PROFESSIONALLY REBUILT WITH A SERVOBORE KIT INSTALLED SEE
WWW.SERVOBORE.COM) If you have this shudder or falter between 3rd and 4th, or all gears, then the transgo shift kit will fix you right up. The transgo shift kit can be installed from under the truck but does require you to remove the valve body from the transmission. I FOUND THIS A GOOD FUN CHALLENGE BUT IT IS NOT FOR THE MECHANICALLY DECLINED AND DEFINITELY NOT FOR THE BEGINNER.
I have felt as you and have replaced idler pully, tensioner, fuel pump, plugs, wires, ignition coil, etc. I rebuilt my tranny's valve body with a transgo shift kit which dramtically fixed the weak lock up (which I think is the problem you have) and I also replaced the tranny solenoid pack just to try and fix my OD.
Tranny shifts good and strong into 1st, 2nd, 3rd, and 4th better than it ever has as a result of the shift kit. OD is still not functional as my OD servo bore is worn. I have also tightened the OD band 1 turn in which reduced my 2nd gear defective shift point from 4500rpm to 3000rpm so at least the truck is driveable with no OD for now.
KEY POINT - **Engine and Transmission are integrated through electronics. If one is bad, the other also falters and/or trips codes.***
FYI - mine is an 03 XLT Explorer with 100,000 miles on it...aka... POS. I have no OD, OD light is flashing and Check Engine light is on. ATM Codes are P0732 and P0735.
I am now on my way outside in 40 degree weather to replace the UPPER INTAKE MANIFOLD gaskets which tend to leak and also result in rough idle.,, Bad running and bad shifting... the position I am in right now makes me upset especially since I crashed my Porsche this morning and now have to rely on this unreliable POS to get me around for a while.
My recommendation to you other than to sell the truck and beat yourself
for buying a ford is to have a transgo shift kit installed into your transmisison which should eliminate your stumble in between shifts and to have the upper intake manifold gaskets changed (there was a recall on this). I do not work for transgo nor am I a mechanic, I'm a do-it-yourselfer so please consider the source of this information. I am simply documenting my findings, efforts and results.... more to come......
I have the exact same vehicle and similar problem - I too would like to say thanks in advance, and any help would be appreciated. We had been to Ford 3 times. They installed platnium plugs, wires, air filter, new timing chain guides (per a recall), fule filter, and did a genreal check. They said the idle was normal and never noticed anything unusual. We have over 800.00 in repairs so far and still have the probelm. Anyone got the answer?
DCN
