93redxlt
- April 21, 2005
- Danville, In
- 93 xlt
About a week ago, the check engine light started coming on my 93 xlt, and the engine has no power when first starting out. Just goes flat. A little scary pulling out into traffic. I also have a lot of pinging under acceleration. Also, at cruise every so often, the engine will stumble for a second, then the engine light comes on. While the engine is idling rough, the exhaust stinks and is producing black soot.
I borrowed a friend's code scanner. I get zero hard faults during the KOEO test, but do have code 157 (MAF sensor below minimum voltage)in the memory and once got a code 158 (MAF sensor above maximum voltage), but that hasn't come back. I ran the KOER tests several times and would sometimes get a 412 code (Unable to controlRPM during high RPM Self-test) and a 536 code (Brake on/off (BOO) circuit failure/not activated during the KOER). I tried the test several times, because the brake peddle and goose codes were probably my operator error.
I have cleaned my MAF sensor...very clean already. I am suspecting that my MAF sensor has gone south, which I believe would explain all of my symptoms, plus the codes. I think if the cat were plugged, the truck would be under powered, and it is not (for a 4.0). I am not getting any O2 sensor codes. I am also going to check & clean my IAC valve.
The MAF sensor costs $100 at Autozone, so I want to be sure. I there a way to check the MAF sensor with a volt meter? Does the brief stumble at cruise speed sound familiar to anyone? Your help is greatly appreciated!!!!!!!!
