Dick Berg
- July 28, 2005
- San Jose, CA
- 1997 Explorer EB 4L SOHC
1997 Explorer, EB, 4WD, 4L SOHC Engine.
I recently replaced the blown left side camshaft chain guide. I was able to do it without having to re-time the engine, based on a procedure by 2000StreetRod. Everything went well, the engine is smooth at speed, great gas mileage, no hesitation, etc. The only problem is the idle is a bit rough.
I checked for vacuum leaks by plugging all of the ports in the upper intake manifold, removed both intake manifolds, which were previously removed for the camshaft guide replacement, replaced both sets of almost new manifold gaskets, replaced the less than one year old EGR to upper intake manifold o-ring, and looked for any cracks in either manifold. I have also sprayed starting fluid all over the place with no change in idle. I also replaced the IAC valve, all with no change in the idle.
I just purchased a code scanner and will hook it up and monitor what I can.
Does anyone have any ideas what could be causing the rough idle? Are there any things to look for with the scanner that might give me a clue to what's going on?
There aren't any codes set. As mentioned, if not for the rough idle, the engine perfoms almost like it did when it was new.
Is there some sensor that could be outputting a faulty signal that primarily and/or only affects the idle?
Thanks for the help.
Dick
Dick
