Rough running after tune-up 5.0 v8
AlexVanEks
Location
Ohio
Ohio
01 Eddie Bauer 5.0
Greetings fellow enthusiasts (and sufferers)!
I recently purchased a 01 (98-01) Explorer Eddie Bauer with the seemingly rare gem of a 5.0 V8. She's a beauty and couldn't be happier even with the 198k miles!
However. I was in line getting pizza and the dreaded check engine light came on. She was studdering like a fouled plug so I went for the check. Sure 'nuff, misfire #3. Attained plugs and wires (motorcraft, or is it motorcrap? Plugs and Napa Lifetime wires). All the wires were probably original or way too old and #3 had some meltage from the plug end. Broke#1 plug and left just the blasted threads, had to have it pro removed (after two days of cursing wjile heating and beating, impact gun, 2ft+ of breaker bar and a shattered EZ Out). 2-4 were a pain in the you know where, I think they were nearly original. #2 was so fouled there was no gap, and all were corroded badly on passenger side.
Driver's side also needed changed but they came out textbook perfect so I think it was a wall job at the dealership at some point. Also have done coil packs and the pcv pain in the butt to reach valve.
Now comes the fun part!
NO CEL and no codes to give
Running like hot garbage, very bad mileage (she said 8 mpg ) and loss of power uphill. I can't feel for sure if there's still a misfire, but my suspicion is something is still amiss.
The worst is running 35mph ironically, she shakes like she's gonna tear apart! Idle sucks too, especially in drive. However, 30 or 40mph are fine, makes no sense.
I have a suspicious rattle that sounds like a catalytic converter shield and a definite leak in the resonator between muffler and exhaust pipe. The louder the leaks, the more annoyed I get. Her running with my foot in her isn't too bad, weirdly.
Plans:
New air filter. Mines full of bugs
Clean MAF sensor
Try to find the @$#& exhaust leak and repair/replace
Fix the stupid sway bar endlinks that just isn't freaking attached on the driver's side
Y'all are a super big help and this forum has saved my butt so many times with my previous Expy that I had to join!
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
shucker1
Metairie, Louisiana
98 XLT 5.0
My first step would be to make sure the plug wires are all going to the right places.
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
I'd not be running it with a misfire. It can be extremely hard on your motor, or damage your cats.
Are you sure you've got the wires correct? I'd pull both ends, and make sure they are seated. If that fails, I'd pull the plugs and look for signs of misfire.
AlexVanEks
Location
Ohio
Ohio
01 Eddie Bauer 5.0
I did check and double check the wires both when I was replacing (did them one at a time) when first replacing, and then again with the new coil packs. I'll have to check the plugs and see if any of them are messed up. I have at most 20 miles on the vehicle since this fiasco and as my only vehicle I don't have a lot of choice when I need to go somewhere :/
I have a feeling the cats are factory original so there's a good chance they're already FUBAR lol.
Thanks guys!
Mbrooks420
High Voltage.
EF Vendor
I ruined the cats on my escape by driving it home with a bad misfire. If your cats were bad, you'd have a CEL.
Maybe get a spark tester and test to make sure you didn't get a bad coilpack.
AlexVanEks
Location
Ohio
Ohio
01 Eddie Bauer 5.0
Vehicle runs a bit better with the new packs so there might have been some breakdown in there. Feels like my old expy that had the exhaust held on with c clamps, when a clamp would come loose (bought it that way, was an expy neophyte or wouldn't have bought it lol).
Air flow sensor and new air filter just got installed. Going to see if it helped. If nothing else it certainly won't hurt!
shucker1
Metairie, Louisiana
98 XLT 5.0
Perhaps a 1\2 can of Chemtool B-12 Fuel Injector cleaner in the gas tank with a full tank of premium gas to help get the injectors cleaned out again?
I do it to mine every so often.
AlexVanEks
Location
Ohio
Ohio
01 Eddie Bauer 5.0
I just got in and washed up. Checked the 1-4 plugs. #2 was fouled but that plug took the abuse when I had to limp her onto the flatbed with the EZOut lodged in the #1 hole. Replaced the #2 plug and fiddled with the #3 wire. The metal sleeve is a smidgen too long but I got a solid fit (I hope). Took her for a spin while hailing a few hundred lbs of wood, was okay until about 15 minute from home, then cel flashed, then stayed on.
Did the check, 7+8 misfire. Checked the plugs and they were okay. Reseated the wires and hit the road after the 5 minute negative off the battery reset. All was good for about 10 minutes, cel flashed. Went off, stayed off, came back on, went off.
Read flashing is a misfire but it won't stay on to get a good reading!
TL;DR:
Wires are new, plugs are new, coil packs are new. New pcv valve, new air filter, MAF sensor cleaned.
Truck runs reasonably, idles a bit shaky. Gas mileage went from 7 to 15 on the screen. Excelleration is reasonable, a bit hesitant going uphill perhaps.
Plans:
+Premium gas
+ Big @$$ can of sea foam brand top engine cleaner. (Supposed to remove gunk according to the can )
Thanks guys!
shucker1
Metairie, Louisiana
98 XLT 5.0
Perhaps you might think about doing a compression check to see if you might have something going wrong inside?
You also may try to put a vacuum gauge on it to make sure all is good up top with no leaks.
AlexVanEks
Location
Ohio
Ohio
01 Eddie Bauer 5.0
I have no idea how to do those :confused2: I will have to raid the forum to find threads for it
I'm going out today to knock the edges off the metal sheaths of the spark plugs. Planning about 1/32" removal, maybe a bit more. The block is corroded to some extent, and the metal sheaths seem to prevent a solid fit.
My CEL has consistently been misfire and I think everything compounding isn't helping. I have a vacation in four days and I /need/ my truck!
Mbrooks420
High Voltage.
EF Vendor
I wouldn't think the sea foam would be needed, and I'd be Leary of doing it with new plugs. I always foamed mine before.
The compression tester installs just like a spark plug. Very easy.
AlexVanEks
Location
Ohio
Ohio
01 Eddie Bauer 5.0
Still have misfires on 7&8 :/ Reset the computer again, going to have to go for a spin and wait for the flash of the CEL again.
I'll have to acquire a compression test tool somehow.
Beginning to think I have fuel injector issues, although the problem jumped from #3 to #7+8 :/ I don't know if the crud the seafoam knocked loose is causing misfire since it's often erratic?
shucker1
Metairie, Louisiana
98 XLT 5.0
Compression Tester; Gauge can be bought at Autozone or any parts store. Remove ALL spark plugs. Disable fuel pump by removing fuse in fuse box. You don't want that coming on during test.
Screw compression test gauge into each spark plug hole one at a time. Crank the engine over several revolutions so you get a good pressure reading.
Your looking for all pressures to be even or within 5% of each other. Normal pressure would be 160-180 PSI.
Low pressure on all cylinders would indicate worn rings. Low pressure between two adjacent cylinder may indicate a blown head gasket.
Low pressure on one cylinder could be a bad valve.
Wet cylinder test would be next for that "Hole". Drop in an ounce or two of light motor oil. Re test that cylinder. If the pressure increases that would indicate worn rings. No pressure increase would indicate worn valves.
AlexVanEks
Location
Ohio
Ohio
01 Eddie Bauer 5.0
You guys are so awesome! I'm going to give the compression check a try soon as I can get the kit. Harbour freight has one for $26
Pretty sure with 198,5k miles, an engine cleaning/rebuild is in order. I don't have any clue how to do that and it's wayyy above my shade tree mechanic pay grade.
We have a shop in town but I have no idea how long it might take and I'd be looking at probably $1000 for a rebuild on a $1150 truck. Can't say that's worth it.
I am SO getting the premium membership here soon as I can - y'all are lifesavers!
shucker1
Metairie, Louisiana
98 XLT 5.0
Why do you think we are here?
Don't underestimate your skills.
Takes time to learn this stuff.
You can do it.
Just be careful.
E 99 Explorer XLT 4.0 V6 SOCH running rough Stock 1995 - 2001 Explorers 3
5 Rough running and backfire through intake only when warm Stock 1995 - 2001 Explorers 11
A Running Rough - 2k Limited 5.0L V8, 143k miles Stock 1995 - 2001 Explorers 3
A 95 w/4.0 OHV - low idle, low power, rough running, gas smell Stock 1995 - 2001 Explorers 7
J rough running and gas smell out exhaust Stock 1995 - 2001 Explorers 0
D 1996 Explorer 4.0 OHV Rough Running and Rough Idle Stock 1995 - 2001 Explorers 5
6 '99 Explorer 4.0 OHV Running Rough Stock 1995 - 2001 Explorers 6
6 4.0L SOHC Running Rough Stock 1995 - 2001 Explorers 13
J 97 FORD EXPLORER lost power running rough Stock 1995 - 2001 Explorers 13
A Driveability help posts and replies (check engine lt and/or rough running) Stock 1995 - 2001 Explorers 14
F rough running when damp Stock 1995 - 2001 Explorers 8
M 2000 ford explorer running weak and rough Stock 1995 - 2001 Explorers 2
C Help::::Running rough and boiling over Stock 1995 - 2001 Explorers 11
W Loss of 4WD+Engine Running Rough=Vacuum problem? Stock 1995 - 2001 Explorers 2
K Running really rough Stock 1995 - 2001 Explorers 0
O Rough Running Mountaineer Stock 1995 - 2001 Explorers 0
R running rough as a hairy goat Stock 1995 - 2001 Explorers 0
J Rough idle/running issues. 2000 merc. mountaineer 5.0 Stock 1995 - 2001 Explorers 2
E 2001 - rough running Stock 1995 - 2001 Explorers 6
D Rough running explorer Stock 1995 - 2001 Explorers 7
A 95 XLT running rough Stock 1995 - 2001 Explorers 5
J Loose Screw on MAF Sensor Truck Running Rough Stock 1995 - 2001 Explorers 2
M 96 Explorer idles rough and wont stay running Stock 1995 - 2001 Explorers 3
J 98' Explorer Running Rough (air in gas tank) Stock 1995 - 2001 Explorers 13
B Running Rough / Missing on a Cylinder 98 sohc Stock 1995 - 2001 Explorers 3
A rough idle / running? gets worse at higher rpm? no check engine light? Stock 1995 - 2001 Explorers 0
J rough running Stock 1995 - 2001 Explorers 1
R 1996 Explorer XLT rough running Stock 1995 - 2001 Explorers 2
J rough running at start Stock 1995 - 2001 Explorers 0
C Rough running... than not Stock 1995 - 2001 Explorers 0
B Rough Cold Start idle/not running well Stock 1995 - 2001 Explorers 0
E 97 Explorer Running Rough Stock 1995 - 2001 Explorers 4
E Grinding sound and running rough Stock 1995 - 2001 Explorers 3
S 1997 Ex 4.0 SOHC running alittle rough Stock 1995 - 2001 Explorers 1
G 2000 XLT 4.0 Running real rough. Stock 1995 - 2001 Explorers 12
M Running rough Stock 1995 - 2001 Explorers 10
K 95 Running rough Stock 1995 - 2001 Explorers 14
1 1998 SOHC running real rough at idle Stock 1995 - 2001 Explorers 2
S burnt rubber smell and rough running engine Stock 1995 - 2001 Explorers 4
A 95 Eddie Bauer Running Rough Stock 1995 - 2001 Explorers 1
B I need advice for a 2001 Explorer Sport that's running rough. Stock 1995 - 2001 Explorers 5
K Rough running when in gear? Stock 1995 - 2001 Explorers 1
T Running/Sounds VERY rough in gear Stock 1995 - 2001 Explorers 2
4 1995 Explorer 4.0 Running rough when I turn the wheel Stock 1995 - 2001 Explorers 11
Y '00 4.0 sohc running rough Stock 1995 - 2001 Explorers 4
N 99 4x4 ranger 4.0 running rough Stock 1995 - 2001 Explorers 3
M replaced egr and tube, now running rough Stock 1995 - 2001 Explorers 2
T '97 running very rough all of a sudden Stock 1995 - 2001 Explorers 2
P My 98 Explorer is running rough. Please help. Stock 1995 - 2001 Explorers 5
9 Running rough after shock install Stock 1995 - 2001 Explorers 9
Similar threads
