Round antena on roof
Lightn95
2013 PIU
There is this round hockey puck looking antenna on the roof of my '13 PIU. Im pretty sure it is the cause of my water leak in the rear of the Explorer. Does anyone know how to remove it? I want to seal it better to stop the leak. It turns fairly easily and I can get under it. But I can't get it out.
Thanks
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
DubsR13
16 PI Utility
Its probably locked from the bottom. I imagine if you remove the headliner you'll see the lock/ be able to confirm the leak.
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
Pics would be helpful.
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
NMO mounts are commonly used for antennas. Go to the 8 minute mark of this video....it may be of some help.
kobresia
Black Hawk
2013 PI Utility
What Jason said. They're pretty much all NMO mounts, a small strap-style pipe or oil filter wrench with some purchase will twist it off. Upfitters seem to really crank down on them during installation in hopes they won't leak, and after a few years of the roof getting hot, the o-ring will stick.
Once you get it removed, your best bet would probably be to get a plug and then coat it with RTV silicone, that's what most decommissioning folks do to patch the roof properly.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve II
Callsign
VE3
....."wrench with some purchase will twist it off." :dunno:
kobresia
Black Hawk
2013 PI Utility
Are you wondering about "purchase"? It's the word to describe a leveraging grip against something, and the puck antennae can be very stubborn. I was trying to remove one from my parts vehicle without damaging it over the weekend. Without the correct tools, which I was lacking, it's pretty challenging...
peterk9
Staff member
Moderator
Callsign
VE3
Thank you. I've never heard it used in that context.
Lightn95
2013 PIU
That's exactly what I was planning on doing. So they unscrew off the roof?
kobresia
Black Hawk
2013 PI Utility
Pretty much, yes. The NMO mount clamps into the hole in the roof, then the antenna base screws down on it and seals the hole with its o-ring.
Portland, ME
2013 Police Interceptor
Thanks
I'll buy the puck off of you!
Lightn95
2013 PIU
I'm not sure how big of a hole will be left in my roof. The antenna is about 3" round.
Do the roofs have 2 skins, or is it just 1 layer? I'm still chasing this roof leak!
kobresia
Black Hawk
2013 PI Utility
They are one layer with ribs. The typical NMO mount hole is 3/4".
One thing to be aware of, the NMO mounts generally aren't watertight without the antenna or a weather cap, so make sure you have a 3/4" plug and some silicone RTV or caulk handy. The mount itself can usually be angled back into the hole and left in the headliner if you don't feel like pulling it and the length of cable out.
Dre Ford Explorer Police Interceptor Utility PIU 0
Similar threads
Mystery ground wire
