Rounded Oil Plug | Ford Explorer - Ford Ranger Forums - Serious Explorations
Rounded Oil Plug
mchilese
Tucson, Arizona
1998 XLT 5.0
Hey guys.
Well, like most things, this started out as just an average oil change. This is the first one that I was doing myself. So I got under my truck, and went to put the socket on the drain plug only to find that it's been rounded off. I let it slip twice, and since I didn't want to make a bad sit. worse, called it stopped pulling on it.
Does anyone know how to remove a rounded off bolt? I found this and am thinking about trying it.
http://www.ehow.com/how_4516975_remove-bolt-rounded-head.html
Does anyone have any experience with this problem?
I called Pepboys to see if they would do it. But they said that they would have me sign an authorization form for them to REPLACE my oil pan because he said that 60-80% of the time getting an oil plug out messes up the pan and they have to replace it. I think that's a high enough percentage that they are bullshitting me and would say it got jacked just for the $600-$800 he quoted to replace it.
I don't doubt that they may mess up a bunch of pans getting the plug out, but I figure there might be better ways than apparently trying with a hack-saw.
Any help would be appreciated. Thanks! :salute:
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
mchilese
Tucson, Arizona
1998 XLT 5.0
Awesome! Thanks for the quick reply. I'll be making a trip over to Sears in just a little bit.
Hartman
Indianapolis, IN
Use a pair of vice grips
Maniak
Moderator-Stock 91-94
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
Hartman
Indianapolis, IN
This reminds me of when I accidentally stripped the tranny fill plug on my old BMW. Except it was reverse hex with about 1" of clearance in front of the bolt. That was fun.
waskly
Crooklyn NY!
its a nut, use a pipe wrench on it.
make sure you pick up a new drain plug first.
also lefty loosey and righty tighty!
mchilese
Tucson, Arizona
1998 XLT 5.0
I like all the ideas. But would vice-grips or a pipe-wrench fit in that little recess?
BigRondo
USMC 1371
Staff member
Moderator
Charlestown, RI
2014 Escape SE
I second the vice grips or pipe wrench with a new one for re-installation.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
jhclance
Forsyth Ga
1996 4dr 4x2
worst case senario i have tack welded a nut to the plug in order to get it out then reinstall a new one and be sure not to over torque it.
Hartman
Indianapolis, IN
On the 5.0 the plug is right there in the open...you should be able to get it off with vice grips or an easy out. No reason to go beating or welding on the paper thin oil pan.
rileyrs
2002 ranger
ive used vice grips for stripped plugs before, works great, doesn't hurt the pan, and then replace the bolt/nut/plug after your done with a new one.
Shortround
Harrisburg, Oregon
2001 explorer xlt
I totally agree with vice gripes. If you put vice gripes on properly and you can't get the bolt out, then you have a problem
DeRocha
NEX Vice President
Moderator Emeritus
Brockton, MA
'93 XLT 4x4
The Vise Grips below are designed to grip nuts/bolts to give rock solid contact on 3 sides. Unlike most Vise Grips this one won't mess up the nut/bolt (no teeth to destroy stuff). I keep one at home and one in my Truck.
Vise Grip part # 7LW
Willard
Bloomington, Indiana
04 Ranger Edge
The Vice Grips below are designed to grip nuts/bolts to give rock solid contact on 3 sides. Unlike most Vice Grips this one won't mess up the nut/bolt (no teeth to destroy stuff). I keep one at home and one in my Truck.
Those look AWESOME! Where can you get them? Never seen any like that before.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
