mstrmp3
- June 19, 2006
- Charlotte, NC
- 99 XL 4-dr 4x4 OHV
99 4.0 ohv 4x4. 149K miles.
This is the symptom, sometimes only after stop and go traffic for about 30 minutes, at idle, the RPMs will suddlenly drop down to 200 and either come back to normal idle after a brief second, or just stall out.
Restarting is quick (not even a second) if it does stall. It is sporadic when it starts, but when it starts (like at a light) the rpms will drop, rebound, or sometime stall frequently.
Air temp is about 92+ when it happens.
There are NO codes! checked with scan tool, no problems found. even after disconnecting batt for 30 min, reconnecting, and running 4 drive cycles.
This is what has been replaced to resolve it.
spark plugs (motorcraft)
wires (duralast) however old wires were replaced at 80K and ohm'd out fine
new ignition coil pack
ECT sensor
IAC valve
PVC valve
new battery and connectors
upper intake gaskets
DPFE sensor
throttle body was cleaned and tps sensor checks ok
MAF cleaned (however it is stock to the truck)
Air filter
Fuel filter
CAM syncro sensor was replaced last year
Coolant flushed 6 months ago
all diffs fluid changed 3 months ago
If it was a fuel issue, wouldn't restarting take longer if the motor was starved?
Could it be an alternator/VR issue?
This happens in Park, Neu, drive, a/c on or off.
I'm about to go CRAZY!!!
***UPDATE***
I replaced the alternator after reading 13.2V at the battery. When I replaced it, the VDC was 14.4 at the battery. No more stalling at stops after 4 days of trying to get it to stall! Finally!
ECT sensor
IAC valve
PVC valve
DPFE sensor
Air filter
Fuel filter
***UPDATE***
