rpm'S TOO HIGH | Ford Explorer Forums - Serious Explorations
rpm'S TOO HIGH
rwmitch1959
lexington, ky
2003 Ranger edge
My 2003 Ranger 3.0 Is Cruising On The Interstate At 65mph And Rpm's Are Very High At 2500 To 2600 Rpms This Is High, Is There A Sensor Problem The Truck Is Using Way To Much Fuel It Does Not Idle Back At This Cruising Speed, What Is The Problem? Is It A Throttle Control Se
It could be a tps or Maf issue-causing the torque converter to stay "unlocked"
try disconnecting the battery, and clean the MAF sensor. Then go for a drive , see if it doesn't behave after showing it who is boss.
maf senor
THANKS FOR THE ADVICE BUT WHERE DO i FIND THE maf sensor on the engine?
WHAT SHOULD i USE TO CLEAN THE MAF SENOR
rodi_2004_26016834
The sensor is right behind ( downstream of ) the air filter
I would also check the shift linkage. Cound down from park and ignore the PRNDL.
Is your overdrive on? I haven't driven my kids Ranger in a while so I don't know the range.
