What rpms are normal with a 4.0 ohv auto tranny 4.10 gears and 32 in tires?
mainly on highway or freeway speeds around 65 mph.
Here's how to figger it out: 1. Find circumference of tires: 32" diam. X pi turns out to be 100.53", or 8.3776 feet. The tire makes 5280 divided by 8.3776 revolutions per mile, or 630 revolutions per mile.
2. Multiply that 630 turns per mile by the axle ratio, 4.10, and you get 2584 as the number of turns the driveshaft (and the engine, if torque converter clutch is locked) make per mile, assuming direct drive, no
overdrive gear in use.
So, at 60 mph, the engine is turning 2584 rpm. (without overdrive gear).
WITH overdrive gear, multiply 2584 by the O/D gear ratio (mebbe about 0.8), so with O/D engaged, about 2067 rpm at 60 mph. imp
EDIT: BTW, this all works out at 60 mph, because that is the same as 1 mile per minute, and we want the engine speed in revs per minute.
