Rubber Brake Line
sledgehammer1990
Doylestown, PA
'94 XLT
Hey there, I was wondering where I could get some new brake lines for the front disk brakes. I heard that sometimes, they can collapse in on eachother. When I press my brake, my truck pulls left a lot. Calipers are new, only 6 months old. New brake pads too. Does anyone have a guide on how to change them and if it is reletivly hard or easy?
mikeinri
04 Explorer, 94 XLT (RIP)
Auozone, etc. will carry these.
They are very easy to replace, as long as the steel lines aren't rusted to a point that those break when you're removing the old and installing the new rubber lines...
Mike
sledgehammer1990
Doylestown, PA
'94 XLT
OK, cool. Yeah, I remember taking them off the when replacing the calipers. So yeah, this should be a quick and easy fix. Thanks!
mikeinri
The caliper side is the easy end. The other end is where you have to be really careful with the rust issues (think rear hard line into wheel cylinder).
Mike
marragtop
balt, md
91, 92, 95, and 2000 xlts
Squirt the fittings with PB Blaster and let it soak for a day before trying to get the line loose from the main brake line.
sledgehammer1990
Doylestown, PA
'94 XLT
Sounds like a plan. I plan on getting the hoses this weekend.
marragtop
balt, md
The best way to get the line loose is with a tubing wrench. If you use a regular open end you will most likely round it off and have to resort to vice grips.
sledgehammer1990
Doylestown, PA
'94 XLT
Tubing wrench? If this is what you are talking about, I have these.
marragtop
balt, md
Yeah, that's it. I guess I should have called it a line wrench. my bad...
mikeinri
Yes, forgot those very important points. PB Blaster and tubing wrenches (aka flare wrenches) are a must.
Mike
