exploderlimited
- February 22, 2012
- buffalo ny
- 2005 explorer 4.0 4x4
hey i had this explorer for about 6 months now, it has bought it with 115k now it has about 120k. the only real complaint i have is that when im coasting between 45 and 50mph I get this pretty noticeable on and off vibration like rumble strips. if i downshift out of overdrive its much more significant, if i shift into neutral it goes away completely. The transmission shifts perfect, and there is no vibration under hard accelerations.
All the wheel bearing are tight, replaced the U Joints and all the tires are balanced. im not sure if this could be a half shaft issue or not. if i put the truck in 4 high the vibration doesnt happen. so im thinking that takes the load of the rear of the truck.
Thanks
Thanks
