runderwo
- August 4, 2009
- Tulsa, OK
- 91 XL
My truck runs great and blows cold air until it gets over 95-100 degrees out.
When it is that hot out, when it is warmed up, the A/C starts blowing warm at idle and the high side A/C pressure goes to 350 (can be brought down to 200 by spraying the condenser with a hose) and also at idle I see the engine temp needle creep up to about 3/4, still in safe area though. If I get on the highway the A/C starts blowing cold again and the temp goes down to the normal 1/2 position.
I would suspect that the fan is not keeping up. But the clutch seems nice and tight when I try to spin the fan. Should I try removing the clutch and connecting the fan directly with a spacer to see if this brings the temp/pressure down? Then I would know that I need a better clutch. Also, what are the chances that the plastic fan blades are flexing. Any other ideas?
