Running rich | Ford Explorer - Ford Ranger Forums - Serious Explorations
Running rich
Kevinh71047
Tenaha texas
1993 EXPLORER eddie Bauer
I have a 93 EXPLORER eddie Bauer 4.0
Whats going on is it s idling rough running to rich drinks lots of gas.changed plugs feul filter oxygen sensors maf sensor with new pigtail I did a eec test my codes is 157 and 998. It did do ok till about a few weeks ago till my light stays on. But even It went off and on my rpm gauge jumped and feels like it ain't shifting into last gear.
Mbrooks420
High Voltage.
1998 Mountaineer AWD
Were any of the plugs “cleaner” than the other? You could have a sticking fuel injector. If your CEL is flashing you probably have a misfire.
Kevinh71047
Tenaha texas
My plugs Are clean I have not checked the injectors what did you mean my cell light. Check engine light is always on.
Kevinh71047
Tenaha texas
What if I used gumout complete duel cleaner but I already used a bottle of this about a few weeks ago
Mbrooks420
High Voltage.
If you find one plug cleaner than the rest it often points to a coolant leak in that cylinder, or a sticking injector. CEL=check engine light. If you clear the codes do they come right back? How old are the wires?
Kevinh71047
Tenaha texas
Yes the light comes back on.
Kevinh71047
Tenaha texas
Well the plugs ain't to old and the spark plug are not wet just got a little carbon is all.
Mbrooks420
High Voltage.
I’d check the MAF wiring. The plugs likely wouldn’t be wet. How old are the wires?
Mbrooks420
High Voltage.
You checked it all the way back to the computer? I’d check the MAF with a multimeter.
Mbrooks420
High Voltage.
If MAF checks out and ALL the wiring ( not just the connector) is good you probably need a new computer.
Kevinh71047
Tenaha texas
Well weeks just looked at the pc and it don't have a black wire on it to test it or does that black wire go somewhere else
roscoe 0202
salt lake city utah
1999 explorer sport
check your o2 senser
roscoe
Mbrooks420
High Voltage.
Are you sure they are correct? Did you get the upstream and downstream ones in the correct place?
Kevinh71047
Tenaha texas
Yes they are in th e right place
Mbrooks420
High Voltage.
Since you have checked everything and are sure it’s good in the harness and the sensors, I’d grab a junkyard computer for your model year and drivetrain package. I’m not sure what else it could be.
Kevinh71047
Tenaha texas
What a drivetrain package
Kevinh71047
Tenaha texas
Plus my koeo says Hard faults present. And it say limp mode
