Your diatribe about searching wastes as much bandwidth a question
ya, but if they dont know how to search, they will just keep asking things that have been talk'd about over and over and over and over......
leading them to the right post is fine , but they got to learn how to search first
We all know how to search. Thats how we got here.
Kudos to the Admin. for cleaning this up.
As for the problem: I don't see a vaccum leak causing a problem, but you can check for a vaccum leak by removing a vaccum line while the engine is idling. If the RPM raises, then you just created a leak so there was not one before.
Since you say the compression is ok, then I don't see a problem with the valves. If an intake valve wasn't closing, it would backfire. If an exhaust valve isn't closing, it would be low on compression and have a misfire. To verify a valve isn't closing and the cyldiner has low compression, pour a couple ounces of oil into the cylinder and recheck the compression. If compression goes up, the problem is the cylinder rings. If compression does not change, a valve is not closing.
Find out which cylinder is missing by removing each fuel injector connector, one at a time, while the engine is running. As you remove the connectors from the injectors, you will hear the engine RPM change. The injectors that you disable which cause the RPMs to change is NOT the cylinder with the misfire. When you find the right one, the engine rpms will NOT change. Once you identify which cylinder is misfiring, it's time to determine if the misfire is caused by fuel or spark. The easiest way to do this is by swapping injectors, coils, wires, or spark plugs with a ones that are known to be good. Before you start swapping things around check the fuel injector connector. Wiggle it while the engine is running to see if that corrects the problem. Another good idea is to clean all the injector connectors with contact cleaner.
If it was low on power (more than normal) without a misfire and considering everything else, I'd look for a restriction in the intake or exhaust. Is the air filter dirty, did you leave a shop rag in the air box, or is there a potato in the exhaust pipe.
What do the plugs look like? Is there evidence the engine is running rich?
Let us know if this happened suddenly or over a period of time.
