Russ's (99ex22) 4406 Swap Thread
99ex22
Wilsonville, Oregon
2000 5.0L 4x4 Eddie Bauer
Here are a few progress pictures from last night. We started at 7pm and called it quits at 2am haha
Everything together..
picture.php
Console out...
picture.php
Drive shafts out...
picture.php
AWD case out...
picture.php
4406 in...
picture.php
picture.php
Linkage installed...
picture.php
picture.php
Ill put the console back in today and try to figure out whats going on with my front shaft (too long)
99ex22
Wilsonville, Oregon
Now that I looked at the picture of the front and rear driveshafts together it looks like they're almost the same length.... That isn't right is it? They said it it was out of a 4.6....
99ex22
Wilsonville, Oregon
Any bright ideas for my front shaft? All the shops around here want 100 big ones...
my pos mounty
Land of Corruption
06 F-350
Actually, if you look at post # 201 of the mountaineergreen thread, "nobodyspecial" has a pic of front/rear shafts together and they look like what you have. Link below to his pic:
http://i333.photobucket.com/albums/m362/7point62/Mountaineer/S1052681-Copy.jpg
I don't recall if they were that close to the same length. I can measure them for you tomorrow if you want...
Ask the junkyard you got it from if they gave you the right one, or if they will take it back.
99ex22
Wilsonville, Oregon
Never mind I got it in:D We took the shaft apart and there was a ton of dirt and old grease in it preventing it from compressing a little more. We also had to take out the rubber seal to get it on so its completely compressed which I don't think is very good? When I have the $$$ Ill have a shaft made or get another and have it shortened. I'm just happy I have a true 4x4 now!!! Here is some pics of the gunk....
picture.php
picture.php
100% completed....:D
picture.php
It shifts smoothly and I have no vibrations or noises exept for a slight whine in first gear...not sure if it was there before the swap or not.
I couldn't be happier with the 4406! I recommend for everyone with the 5.0 and awd to do this! It's well worth the effort.
Sbyrne97
Mason Neck, Virginia
97' Mountaineer
rubber seal? the one in the differential? or is it on the shaft?
99ex22
Wilsonville, Oregon
It was on the shaft.... I'm not concerned about that, I'm just concerned about the shaft being fully compressed so there is no play. Then again there doesn't have to be play in the shaft because our front diffs don't move right?
Sbyrne97
97' Mountaineer
correct, still are you sure its not the slip yoke seal...all im saying is it may cause premature wear to the shaft
99ex22
Wilsonville, Oregon
Tested her out today...
picture.php
I have more pictures in my registry, the link is in my signature!
This thing is a lot of fun in 4lo!
Lanky
Paducah, Ky
2000 xlt awd
What happened to the front "board" bumper you had? What did you have to do to get the bumper to fit? Did you do the body lift to keep from "adjusting" the belly?
My awd t/c front output bearings are roaring and vibrating pretty good. Got a quote of $800 to rebuild it without even asking what kind I had in it. I think this would be an awesome project eventhough the ex rarely if ever goes offroad. It would be sweet if someone made lockout hubs to disengage the front end.
jds3403
new bern
'99 5.0
yeah they do, AVM makes hubs that are designed for 98-early 2000 rangers that had PVH style hubs, Pulse Vacuum, in early 2000 ford switched the ranger front end to the explorer style live axle front end. so you can swap the explorer's front wheel bearings and shafts for a 98-early 2000 ranger and swap the pvh guts for a set of AVM hubs and have an unlocked front end for true MPG results. :salute:
good job on the swap looks awesome and love your truck too looks good with the lift and tires with stock rims.
