Well, it all depends on the prep. I bought the entire POR-15 system to try on an emerging spot on Shamrock. I spent the entire 4th of July weekend diligently observing the times, and process. After sanding, using their surface prep chemical, their metal treatment chemical, 3 coats of POR-15, their tie-coat primer, primer, 3 coats of green and 4 coats of clear, it started to bubble after about a month.
I'm not sold on it. I really dont think it's as good as some of the claims you read like the guys that painted a car with it, then it sat in New Orleans for the flood, and after a few years, the parts painted with POR are still like the day they painted them and the other metal is gone... I don't think so.
This was the inside of the fender I did- it was painted on the 4th of July, so about 2-1/2 months ago... Cleaner, metal prep, 3 coats of POR-15. The outside I've re-done about 3 times. Every time now it takes a couple of trips in the rain and it starts browning out again, it's like it pinholes just like the guy said in the test.
Here are the pics I sent POR-15...
The areas I did:
After prep, primer, paint, clear
...and after buffing out:
The stuff is a ***** to work with- it seems like any small void allows rust, so I didn't sand it, instead allowing some paint and lots of clear fill some voids to smooth out a bit. It looks good from 5 feet out, but if you get very close, you can see the application.
Then after a month you can see the application as well as the rust already starting to bubble out.
Since then, I've sanded, reapplied, and it's starting again. The truck had nothing when I got it, and I think by messing with it, I made it worse. All I know is that I paid about $120 for all of the stuff I got from POR, and for a month before seeing rust again, I wasn't too happy.
I painted the underside of the rockers on Snowball with Rust Bullet, and for ease of use combined with how it lasted- I'd get Rust Bullet for myself if I had to do it over again rather than POR-15, but that's my opinion...
