Mumbl3s
- January 8, 2018
- El Paso
- 91 Explorer Eddie Bauer
So after putting my engine together I got it running but it's been running rough, like misfire, pops and bangs out the exhaust, and it almost overheated. So after a night of some beer and a lot of Johnny cash (possibly the other way around) I've tried diagnosing but it led me to pulling the cylinder headsand well this is what I found;
So the question is, what the heck is this!? I'm checking to see if it's flat after I get off work tonight because I think it might be the water and coolant cleaner I used to flush the system leaking into the cylinders.
The previous owner was using two of those rubber freeze plugs which is the reason why I pulled the motor originally, he might have over heated the moter causing it to warp but I wouldn't have noticed till I pull the heads off.
