BUXTER
- January 13, 2019
- SUMMERVILLE
- 2001 MERC MOUNTY 5.0 AWD
- LESSON here guys is when u pull Water Pump & see rust damaged fasteners at the 'ears" of Water Pump its NOT because the water from Water Pump weep hole ran UPHILL & did that - Its because u have Coolant leak at the Gasket between Timing Cover & Motor thats secured by the Water Pump "Ear Fasteners" - AND maybe a leaky Water Pump.... so call Time Out & PULL TIMING COVER - Unless u like tons of REWORK. - I did Water Pump, all new Hoses, new Radiator, Electric Fan, new Thermostat & Housing... & After all that I had this VERY intermittent leak I could never find that AINT intermittent anymore... When u cut car off it leaks until pressure vents down - I still have not seen the pinpoint source of leak but its coming fm front of Pass Side Head area for sure - I'm a dummy for NOT replacing Timing Cover Gasket when I did Water Pump~!
