03explorereb
- February 18, 2011
- cuba, missouri
- 06 explorer xlt
Gents,
My wife's 06 has a major problem concerning second gear. 4.0 with the 5r55s. vehicle upon starting from drive and normal acceleration will go through 1st fine but when it hits second there is a terrible grinding noise. shifts points seem normal through all gears. no real clunky shifts. the grinding carries through the gear but is quiet at third gear and beyond. what the hell?
Supposedly the transmission was rebuilt a short time before we purchased it, about 30000 miles before. I changed the transmission fluid and filter with Valvoline mercon V about 1000 miles before this problem. fluid looked fine with normal wear. also pulls through second with no noticeable loss of power.
engaging every gear, it tries to pull forward. drop the gear shifter to second and try to pull forward, the transmission binds up, almost acting like a transbrake in a drag car and refuses to pull forward. I haven't pushed it beyond 2000 rpms doing this. but definite binding with manual selection of second gear. drop it in drive and it pulls away with no problem except for the grinding during it's time in second.
I have an Autel scan tool and it comes up with zero transmission codes, zero engine codes. it's a pretty good tool. is there something else I can look at, perhaps line pressure or solenoids on the scanner that might tell me something about what's going on? I am looking to pull the transmission but don't want to do this if it's something stupid like a solenoid failing to engage. as always I value any and all opinions!!!! let er rip!
