jsgoofn
- July 13, 2015
- Beautiful Colorado
- 2022 Explorer ST-Line
Earlier in this thread, there was a breakdown of possible recalled trims and the 2.3 RWD was listed but the AWD was not. So, who knows what Ford is up to.Interesting! My 2021 XLT 2.3 2wd one bolt was recalled, it was built in June.
Fantastic explanation!Affected vehicles were built with a 3-point mounted axle design," Ford's report said. "On some units the rear axle horizontal mounting bolt may fracture. Powertrain torque through the driveline causes axle rotation of the pinion angled towards the subframe, which exerts a bending force on the rear axle bolt. Peak torque is normally experienced during a launch event."
"The joint design is not robust to peak axle input torques and manufacturing variability. The primary contributor is insufficient bearing area for maximum joint loads. This results in bearing area deformation, increasing bending stress on the bolt, which may lead to a fatigue failure," Ford said.
Signs of fatigue failure include loud grinding, binding or clunking noises from the rear end of the vehicle. The remedy for the issue is twofold. Customers will get a software update that will enable a feature where the parking brake will automatically be applied when the vehicle is shifted into park. Owners of some earlier examples (or any that show signs of fatigue) will get new mounting components for the rear axle as well.
Dealers will be notified beginning in April; owners will receive notices by June 10.
The way Ford writes this makes it look like the software "fix" is going to make things right without explaining why they are doing this. It only keeps an affected vehicle from rolling away After the bolt fractures. I guess their liability concerns are addressed by this.
