My home and shop is off the grid completely
I have lots of solar panels and lots of batteries
10,000 watts of solar panels will only
Make 10,000 watts sometimes, during perfect conditions, with clean panels, aimed properly
Hydro and wind can help, hydro is the best option if you can get the water, water power happens 24/7
Some places get more sun than others, for them solar might be the answer.
I would challenge all of you to take uour homes off the grid, even just for testing. There are 6 of us here and a truck shop, this is a modern home with many flatscreens iPads, PS5’s, pellet stoves, two kitchens, etc etc. now try to power everything from the sun and your batteries. Good luck!! After you sort that out now try to add a couple of electric cars
You will be needing additional power from fuel, water, air… solar and batteries just are not there yet. I have 8 lithium batteries they were $900 each and will last about 10 years. I also have 16 agm batteries that will last 10-15 years, they were $300 each. Lithium is still very expensive…. Solar panels are coming along… but to think you will not need fuel with solar, well you had better live under full sun 12 months a year. The up front costs are huge, batteries are very $$$$$, solar panels are way up right now, the wires are all copper which is also very $$$$… going off the grid requires a huge up front cost and then maintenance
We use a military tactical quiet turbo diesel 3 phase 15,000 kw gen set to produce power, it can power a small village in the desert or in the arctic, it is very efficient, quiet and reliable. However diesel is the most expensive fuel…. Of course! Propane is cheap but it takes 5 times as much. Diesel is so heavily taxed even the road tax free stuff is more expensive then premium, (unleaded gasoline would take 3 times as many gallons to make the same power)
Diesel is still our best option for generating power here at the homestead until I can build a dam and get enough water pressure to run a hydro generator. It’s a sad state of affairs really, diesel is easier to refine it should be much cheaper. I can also run on bio fuels and if needed we can create our own diesel… practical? Not really, but possible.
Go for it, take your home off the grid, it is becoming more and more popular and more and more possible. Heck even just take part of your home off the grid, maybe your man cave or just the computers.. install a 12v solar powered system just for charging devices. See what it takes in solar and batteries just to keep 6 smart phones, some
Cordless tools and a couple of iPads charged up… those
Little lithium batteries are everywhere now days they suck a lot of juice you will be charging them with fuel one way or the other
