Sandersons welding
doubletime47
Sullivan NY
'01 sport
Has anyone ever heard of or used any of this guys stuff? He has a Ebay store and I guess he makes his own shackles and lift kits. They are alot cheaper than the name brand alternatives. This is a link to his ebay store...
http://stores.ebay.com/Sanderson-welding
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
The Feedback is a little on the low end but I'd buy. As for the shackles, they dont really 'break' so I'm sure it'll hold. The only thing I'd worry about are the tollerances -- sometimes people make shackles that are too narrow and its a pain to get the shackle to fit. But I doubt that will be a problem.
manaen
Clear Spring, MD
2011 Xterra Pro-4X
most good ppl on ebay have a 100% rating, but how badly could he possibly screw up a set of shackles. I would say use paypal for the protection and give him a try and let us know if it works out ok.
jad2411
El Paso, TX
2007 Brown eb
BTW if you're going with the shackles you' need to buy some grade 8 5' 9/16x12 screws, I got them at lowes, 4 screws + nuts for $20 the original ones are a little short, just wish I had bougth them before doing the swap:rolleyes:
doubletime47
Sullivan NY
'01 sport
Ok I just bought them. I post again later after I receive them.
toypaseo
Flunked daycare
outside shovelling snow
................ 96 XLT ™
Shouldn't the middle piece be welded all around, instead of just welds on the sides...?
or am I not seeing the full weld...?
doubletime47
Sullivan NY
'01 sport
I see what you meen. I hope its just the photo... I'll let you know when I get them.
TheChadders
Parker CO
97 XLT
just to let you guys know this is the guy i bought my shackles from and they are very well built in my opinion and i have been running them for 6 months no problem
Chad
jad2411
El Paso, TX
2007 Brown eb
Just took this
Seems it's only welded on the sides, but not sure that makes any difference
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
That should be more than enough -- that shackle can probably withstand at least 5,000 lbs of static tension load if it were rotated horizontally like an I-beam.
Similar threads
