My Ex tends to have little spots (and some big ones) where rust has made a small hole etc.
I sand these out and use bondo to try to fill in any imperfections even if they are small.
Is Problem is: Can't seem to make the repair unnoticeable - as in you can still see the perimiter of old paint around the repaired area (not in color, but you see a little 'ridge' no matter how small..
Is this just a sand paper grit issue? or should you really sand a "larger" area if it makes sense to help hide the transition (from new to old) paint??
If grit - what grit # do youz go to?
Tips appreciated. This is really a pain.
