SAS front, what to do on the rear?????? | Ford Explorer - Ford Ranger Forums - Serious Explorations
94ZebraRanger
Laramie, WY
95 Explorer XLT
I am wondering if I do an SAS in the front of my 95 Ex. What do I do to lift the rear to match the front???? SOA or????
Tim
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
wow..
Trckmagik
Ole Bag
Moderator Emeritus
Celina, Texas
Springs !!
bmxking5
Monroe, GA
'93 Sport & '96 XLT
Robb, would a 7.5 Ford Bronco2 axle be a wise choice for the rear? I NEED to SAS the rear, I can get so much more flex with one!
CodePoet
Indianapolis, Indiana
1993 XLT
bwahahaha
soa
ilfatmnsw??!!!
Texplorer
Morgantown, WV
96 XLT 4x4 4.0
Why would you guys SAS the rear, the SAS is the front is gonna give him about 6" of lift. If he wants to match that in the rear hes better off switching to the new IRS, you can lift that with ease and it flexes so much better in the rear than a SAS'ed rear.
j602
resident ******
Dothan, AL
'92 XLT
You need torsion bars.
94ZebraRanger
Laramie, WY
95 Explorer XLT
Ask a simple question and get BS. As far as I know there is only the superlift either springs or blocks. Nothing over a 3-4". I am wanting to know what options do I have with lifting the rear to match the front SAS.
Tim
tgertz77
Monterey, California
'91 XLT 4x4
Tim
Spring over axle in the rear will give you 5-6 inches to match the front.
best way to do it.
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
O'RLY?
unclemeat
Richmond, VA
91 sport
How about a wing for the rear? It works for a honda. It should really work for a SAS rear X.
bmxking5
Monroe, GA
'93 Sport & '96 XLT
94Zebra - Maybe the reason people are saying these things is because it's an obvious answer. If you have the skill to do an SAS, and know what that is, you'd probably know how to lift the rear. :confused: Also, nobody can answer, "What do I do to lift the rear to match the front SAS?" An SAS is CUSTOM. It can be anywhere from 6-20+ inches of lift. Kind of hard to answer a question like that.
j602
resident ******
Dothan, AL
'92 XLT
Actually, it could be anywhere from 0 - 20" of lift. ;)
CodePoet
1993 XLT
Hopefully mine will only be about 5"s over stock...dang bmx, way to spread mis-information GAWD! :D :confused:
LOL
expo5.0
Red Wing, MN
1996 xlt
why are there ads in the middle of the thread?
bmxking5
Monroe, GA
'93 Sport & '96 XLT
Everything I read was that you needed atleast 6" lift to fit, and that was with hacking up the engine crossmember. But you are correct Josh. I guess if you pulled the motor and it's crossmember, you could have 0" of lift over stock. :p
Jefe
Clarksville, TN
'00 XLT 4x4
Also depends on how much up-travel you want. If you didn't mind 0 up-travel you could easily get away with 0" of lift. :p
