SAS questions | Ford Explorer Forums - Serious Explorations
SAS questions
rguy
Republic of Texas
'91 Explorer 4x4
I've searched but can't find an answer. It may be that the answer is too obvoius. Sorry if it is, but when doing a SAS why are the coil buckets replaced? Is it the size of the springs?
Also, I've noticed that when the coil buckets are replaced they are also spaced out off the frame rails. Why is this? Can the spring mounts on the axle not be relocated?
As for a trac bar, is it possible to use this off another vehicle or does it have to be custom?
Thanks.
Rob
Dannyboy: I replaced mine to scoot them forward a little further, redo the shock mounting and now my coils are secured top and bottom. I've seen them modified and put on the stock coil buckets but it isn't too much work to make it work.
Dannyboy: Depending on the axle, you can do anything. You may be seeing full width stuff that needs to have the buckets moved outwards. I for one did not move mine outwards, I narrowed a Dana44 and they all line up fairly well.
Most track bars are solid, my answer to this was to find one that fit the dimensions that worked. I chopped the end off of the one that came with my front axle and chopped another one up from the rear of a Jeep TJ and they happened to alaign the way I wanted. I drilled, tapped and used a piece of threaded rod, but if I were to do it again I would thread the two ends and use a bulkier tube that would sleeve the setup. (see pic)
Thanks.
Rob
Good luck.
