SAS Steering? Buy Mine- Complete with Heims and DOM
Status
Not open for further replies.
Kirby N.
Colorado Springs, CO
1991 Ranger
Hey guys. Thought I would put this here so those of you who are doing SAS can use it if you need it. I am selling the steering setup on my SAS.
Here is my Setup Description with Pics:
more info on my SAS can be found here
Steering:
I purchased all the Steering link parts from RockWare (http://www.rockware.net/)
4 3/4" Heim Joints with a 3/4" hole (2 Left hand Threads, 2 Right Hand Threads)
Weld in Threaded ends for the Tubing
1 1/8" Seamless DOM tubing
I used 3/4" Grade 8 Bolts for all the Steering. Drilled out the Pitman Arm and the knuckles.
I also used Misalignment Bushings for 3/4" Bolts from Poison Spyder Customs (http://www.spydercustoms.com/). I used 3 1/4" bushings and 1 3/4" bushing
Steering Links THEY HAVE BEEN FRESHLY PAINTED AND THE TIE ROD IS CURRENTLY MOUNTED OVER THE KNUCKLE, EITHER WAY WILL WORK
I put an "s" Bend in the Drag Link to keep the Heims with in Misalignment travel through out suspension cycle. Both the Tie Rod and Draglink are mounted over the knuckles (not pictured) and the Tierod has a small bend in it to accomodate the draglink as it fully compresses
I am selling the steering setup on my SAS. I have decided to go another route. It is made out of beefy DOM- 1.25" OD ~ approximately 1/4" Wall - not sure how to specifically call that what it is! (See pics for detailed look). And 3/4" by 3/4" Highest quality Chromoly Heim Joints or Rod Ends (3/4" Holes and 3/4" thread). I used wled in Thread inserts of the same quality and Jam nuts of the same quality. Two Left hand Heims are on these links and Two right hand Hiems are on these links so that they adjust by simply loosening the jam nuts and turning the link (it is not neccessary to remove the whole link). The Bolts are Grade 8 3/4" of varying lengths depending on component. The nuts are Grade 8 mechanical locking nuts.
Here is what I will include:
- Bolts, nuts, washers to mount to pitman arm and knuckles
- Draglink with "S" bend for increased travel
- Tie rod with slight bend in passenger side for increased up travel on the drag link
- 2 Hiem joints (one left, one right) for drag link
- All the misaligment bushings
All the heims are in awesome shape. NO SLOP. This is one of the toughest setups out there and I spared no expense in making it. It is the highest quality parts available. Will fit a F150 or Big Bronco Axle that has been narrowed to EB width (approximately 6"). I believe it will also work with an EB axle, but it might have to be one with f150 knuckles. The knuckles and pitman arm will need to be reamed or drilled to accept the 3/4" bolts. Detailed PICS
DOM
Heim, Misalignment Bushing, Bolt, Washer
I have almost $400 in this setup. It is ready for someone to take a huge part of thier SAS headache out with a simple bolt on. If you have priced this stuff and looked into building it you know it costs some serious cash and is a huge headache to build right. This is a great deal for someone.
$250/ Offer
Status
R New to the forum and have sas'd explorer Solid Axle Swap Registry 9
S SAS Mountaineer undrivable Solid Axle Swap Registry 29
johnny499 '98 mountaineer v8 hp44 sas soa on 35's Solid Axle Swap Registry 7
2TimingTom '97 XLT Dana 30 SAS Solid Axle Swap Registry 24
1 1-MEAN-X's '01 Sport SAS Registry Solid Axle Swap Registry 11
01STrunner 01STrunner's Sport Trac D44 SAS/SOA Solid Axle Swap Registry 79
S 98 sport SAS help Solid Axle Swap Registry 1
D 94 ex sas Solid Axle Swap Registry 13
9 here is my sas ranger on 35's Solid Axle Swap Registry 4
janderson4010 bronco II 3link d30 sas Solid Axle Swap Registry 10
M My SAS 97 Explorer Solid Axle Swap Registry 15
W 99 EB x SAS D44. Solid Axle Swap Registry 55
R List of Useful Threads Ford Explorer & Ranger Solid Axle Swap - SAS - Registry Index Solid Axle Swap Registry 31
F 91 sas swap Solid Axle Swap Registry 12
B 1999 Ranger SAS (Dana 44/Ford 9 Inch) Solid Axle Swap Registry 18
J The Unappreciated X SAS Solid Axle Swap Registry 11
T My 2nd gen ex SAS Solid Axle Swap Registry 31
9 94 Supercab Splash SAS Solid Axle Swap Registry 23
CodePoet 93 xlt sas Solid Axle Swap Registry 7
MEANEXPLODER 91 xlt dana 44 hi-pin sas Solid Axle Swap Registry 17
N '91 Ranger XLT SAS Solid Axle Swap Registry 2
chad551 2002 Sport Trac SAS Solid Axle Swap Registry 141
S 92 ford ranger sas Solid Axle Swap Registry 9
L Lifeguards sas registry Solid Axle Swap Registry 23
R Old member first time posting. My SAS. Solid Axle Swap Registry 71
SVO42 SVO42's 1-ton SAS Solid Axle Swap Registry 121
S 93 x SAS Solid Axle Swap Registry 52
D Dangeranger SAS done Solid Axle Swap Registry 29
CheapThrillEX SAS and New Family Wheeler Solid Axle Swap Registry 19
mtwheelin mtwheelins sas Solid Axle Swap Registry 15
IZwack IZwack's SAS Registry Solid Axle Swap Registry 10
F Fat Cat's 99 SAS Solid Axle Swap Registry 80
Spas Captain Morgan, '95 D44 Sas Solid Axle Swap Registry 199
Burns 1991 Full Width SAS 44/9 Solid Axle Swap Registry 31
sn0border88 Sn0border88's SAS'ed Solid Axle Swap Registry 23
9 my 97 ranger sas,302 powered. Solid Axle Swap Registry 11
Stic-o '99 Full width SAS 44/ 8.8 Solid Axle Swap Registry 28
section525 Section525 - Explorer V8 D44 SAS Solid Axle Swap Registry 38
J johnny5_72's 89 Ranger Dana 30 SAS Solid Axle Swap Registry 30
9 9sport6's Fix aka sas Solid Axle Swap Registry 40
S SAS Pics w/ Questions Solid Axle Swap Registry 53
F FullFootNotch's SAS on 38s Solid Axle Swap Registry 24
S S10slayer's 99 ext cab ranger sas on 36s Solid Axle Swap Registry 12
-=DaemoN=- Daemon's SAS Solid Axle Swap Registry 30
F littlefoot sas on 38's DONE!!!! complete with baptism pics. Solid Axle Swap Registry 53
S '97 Ranger SC, D44 SAS... Solid Axle Swap Registry 9
Y Yomies D30 SAS Solid Axle Swap Registry 105
J Jefe's 2000 XLT SAS Solid Axle Swap Registry 8
madmike MadMike's 93 SAS Solid Axle Swap Registry 49
gavin 1986 Bronco2 SAS Solid Axle Swap Registry 5
Similar threads
