sas swap | Ford Explorer Forums - Serious Explorations
sas swap
jlove21
westland,michigan
'93 xlt
need some help with my swap.I got a dana 44 and a ford 9. the ford 9 was easy to install but im having some problems with the dana 44. I bought the james duff 5.5 coils, buckets,drop pitman arm,and drop radius arm brackets. I have almost everything put together except for the radius arm brackets. I don't know where to put them. Im using the stock 79 bronco radius arms. anyone have any suggestions or have used these brackets with there swap.any advise would be greatly appreciated.
You can pretty much put them where ever you want to adjust the wheel base to where you want it. No set place they "have" to be.
listen to him; he's done the same swap, only with JD arms instead of stockers. same concept though.
I really appreciate all the help
post pics when your done would like to see how it looks.
