91ROKKRAWLER
- December 6, 2007
- Bend, OR
- '91 Xploder
So I've decided to use a Jeep Dana 30. It'll be on explorer rear leaf springs. since I only drive off road about 40% of the time, I figure it'd hold up. our dana 35 front axles are reverse cut correct? and the vacuum actuator... can a remove it along with the passenger axle, put a drivers side axle in it and just block off the plate? the steering is very similar to fords steering so what would i need to change to get it to work?
