Isaac
- September 20, 2001
- Williamsport PA.
- '92 XLT 4X4
Hi Again.
more Research for the weekend at the Yard.
This Tread is on parts from a 97' Mercury Sable.
I pulled a complete Mass Air meter from a 97 Sable, with a 3.0 liter 24valve v6.
It is a plastic unit, very simalure to those found on the after market, it is extremly larger inside then the stock 91-94 Explorer's, mass air's.
and yet it bolts up with absolutly NO MOD's to air ducting, or air box! (will also work with after market air intakes if the stock mass air is still in use)
The gasket between the air box and mass air's are also identical.
The stock Mass Air sensor will also bolt directly into the unit!..
there is one hang up in the instailatoin of this however.
Where the tube to the TB, attaches to the mass air unit, is a VERY tight fit, due to the outside diamiter of the sables mass air unit being slightly larger then the Explorers, there is a small outter lip on the unit that i cut away to make the whole thing go easyer. it did go on, just needed a little more efford then stock.
This is also the same units used on the Ford Taurus's with the 24v 3.0liter v6.
This has only been proven usefull with the 97' Taurus's and Sables, with the 24v3.0 liter v6, For the 91-94 Ford Explorer's 4.0 liters.
The results as tested on a 92' Explorer 4.0 were noticably qwicker engine rev up, and a bit more high rpm power.
I as of yet have no exsact milimeter sizes on this unit, but it is as big if not Bigger then units offered on the aftermarket (it is roughly twice the inside size as the stock one found on 91-94 Explorer's)
If Enough People are interested i may consitered stocking these units and doing the small mod to make them fit easyer and selling them, this all depends on how many people would be interested in them.
Hope this is Usefull!
Isaac
Salvage R&D
Isaac
Salvage R&D
