-junior
- June 2, 2010
- south jersey
- 05 Explorer SportTrac XLT
Hello Everyone,
I just wanted to review and share my experience with my recently purchased Scangauge II.
The Scangauge is going in my 2005 Sport Trac XLT
Scangauge arrived timely from Amazon ($160-free shipping)
http://www.amazon.com/ScanGauge-Com..._1?ie=UTF8&s=automotive&qid=1280417767&sr=8-1
Fit perfect in the ODBII directly below the dash/streering wheel (in the middle of dash to the right of the emergency brake.
I ran the cable from the OBDII threw the dash and up behind the center console and just wedged the RJ-45 between the foam padding of the dash and center console and mounted right under heat/ac controls. In the first attempt I just used velcro included with the Scangauge but I didn't really like the results. So the second attempt I tried RTV and it was just too messy, then moved to a "GOOP" alternative, but the dry time for mounting was an hour, and button pushing would move the adhesive. So I finally settled on just straight up crazyglue. Mounts clean and dries extremely fast. As a warning though, I mounted on the removable head unit bezel as you can repaint that if needed. After removing (see issues below) the crazy glue did remove some of the paint off the plastic.
After getting installed and operating for a couple of days I noticed the Scangauge would automatically shutoff while driving, oddly enough only in the afternoon and evening, as it was summer i thought it was a heat issue, because it would work great in the morning. But after a couple more days I noticed the Scangauge would stop reporting metrics, just go blank on the RPM's or fWT during operation.
So I called up Scangauge and they just said this was a known issue with the Explorer Sport Trac and that they would be sending me a new unit immediately. I was very impressed with their customer service and a couple days later the new unit arrived with a prepaid return envelope for the old unit. Before I shipped it back I checked the versions on the old/new.
OLD:
NEW:
Since the replacement came I haven't had any issues with the Scangauge, so if anyone has any issues with the Scangauge in their Xplorer or Sport Trac, check your version and give Scangauge Support a call.
OLD:
NEW:
